GefenTV GTV-CR-5SP Speaker System
Surround sound speaker system designed for your bedroom or conference room
Gefen today announced the GTV-CR-5SP wall-mountable, five speaker system is now shipping. The GefenTV Conference Room Speakers are ideally matched to the GefenTV Home Theater Audio Processor's speaker binding posts, offering powerful sound quality for small to mid-sized rooms. Each two-way speaker offers a ported design with built-in wall mountable capability. Speakers are sleek, attractively packaged, engineered for fine quality sound and tuned specifically for the Home Theater Audio Processor. Their elegant finish is designed to match any decor. Together, these two products supply excellent surround sound in bedrooms, dens, dorms and small conference rooms.
The GefenTV CR-5SP speaker system consists of 5 exquisitely designed and tuned surround speakers which perfectly compliment the small confines of a bedroom or conference room. The GTV-CR-5SP speakers have been designed for high-quality audio fidelity rather than booming bass and high volume output. These speakers feature handsome exterior construction and will fit stylishly in a variety of decors. They come ready for wall mounting.
GefenTV GTV-CR-5SP Speaker - FrontGefenTV GTV-CR-5SP Speaker - Back
The GTV-CR-5SP speakers are perfectly suited to work with any audio amplifier, especially the GefenTV Audio Processor, for which they were designed.
How It Works
Simply connect the GTV-CR-5SP speakers to an audio amplifier. The GTV-CR-5SP speakers are equipped with 5-way binding posts having connectors as follows: bare wire, spade lug connectors, pin connectors, and two types of banana plugs (single and dual).
Once all AV system connections are established, set the amplifier's volume to a low level, turn on all connected AV equipment, and then increase speaker output volume to a comfortable level.
Features:
  • 5-speaker surround audio from carefully designed and tuned speakers
  • Incredibly pristine sound from a compact design
  • Designed to fill small rooms with high-quality sound
  • Speaker baffle naturally tilts upward on flat surfaces
Specifications:
  • Low Frequency Driver: 1 X 100mm With 25mm Voice Coil, Ferrite Motor and Cone
  • Low Frequency Driver: Pulp Paper Coating Black & Surround Nbr Rubber
  • High Frequency Driver: 1x 25mm With Neodymium Motor & Silk Dome
  • High Frequency Driver: Frequency Response: (-3db) 75Hz @ 18kHz
  • High Frequency Driver: Frequency Response: (-10db) 60Hz @ 20kHz
  • High Frequency Driver: Crossover: 2.2kHz @ 2nd Lf And Hf
  • Rated Maximum SPL (Sound Pressure Level) Average: 99db / Peak 105db
  • Rated Maximum SPL: Long Term Power 30W / Short Term Power 50W
  • System Sensitivity: (2.83V@1m) 85db
  • Nominal Impedance: 4 Ohms
  • 2-way Reflex Enclosure
  • Medium-Density Fiberboard Enclosure
  • Plastic Frame Grille With Gray Cloth
  • Matte White Finish
  • 4 X EPDM Transparent Feet
  • Dimensions: 6.0″ W x 10″ H x 8.25″ D
MSRP:
  • GTV-CR-5SP – $999 (five speakers)
  • GTV-CR-3SP – $599 (three speakers)
  • GTV-CR-2SP – $399 (two speakers)
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
