Networking
GefenTV Ethernet over PLC
Extend Ethernet Throughout the Home or Office With No New Cables Using the GefenTV Ethernet over Power Line Cable Extender
The GefenTV Ethernet over PLC Extender offers consumers one of the easiest, most convenient methods of Ethernet distribution available today. Users can access the Internet from any room in the house without rewiring or running new cables. Instead, they simply tap into their existing, in-wall power line cables to extend up to four Ethernet connections throughout their home or office. A DSL, cable or satellite Ethernet signal is distributed throughout the home using small sender and receiver units equipped with Ethernet RJ-45 ports that transmit data up to 200 Mbps to guarantee a rapid data delivery.
The ability to utilize the power lines in the walls of your home or office to access the Internet saves money on cabling costs while improving the installation process. No additional cables are needed to connect the GefenTV Ethernet over PLC sender unit to the receiver, which can be placed up to 1000-feet (300m) apart.
The solution is designed for simplicity. The sender unit connects your active DSL, cable or satellite Ethernet router into any standard wall-jack power outlet. The receiver unit is connected to the power outlet in another room where you’ll be working. Once both units are powered, four Ethernet ports on the receiver unit will be active.
All 10/100BASE-T Ethernet protocols are passed through the GefenTV Ethernet over PLC Extender at speeds up to 200 Mbps making it perform better than some of today’s wi-fi systems. Built-in security codes protect the system.
Gefen also supplies a GefenTV Ethernet over Coax solution, which allows users to connect their sender and receiver units to a home’s existing coaxial cable to distribute the Internet to any room. The sender unit links the Ethernet signal to the in-wall cable infrastructure using a coaxial port, while the receiver delivers four active Internet connections to any other room in the same building.
Additional Information: GefenTV Ethernet over PLC
http://www.gefen.com/kvm/dproduct.jsp?prod_id=5274
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
