Gefen Wireless USB Extender Liberates Digital Audio Controls for Yamaha Live Sound Department
CHATSWORTH, CA — In order to demonstrate the portability and high value performance of its 01V96V2 Digital Mixing Console, John Schauer, product manager for the Live Sound department of Yamaha Corporation of America, selected Gefen’s Wireless USB Extender. Schauer can control the 01V96 from the USB port using both Macintosh and PC computers.
“We wanted a simple wireless solution to allow control from a distance, and without cabling,” he explained. “And the Gefen extender works great.”
The Gefen Wireless USB Extender enables data transmitted through a USB port to be delivered up to 100-feet in distance from the small sender unit to the receiver with no connection cables in between.
As the product manager for Live Sound, Schauer’s role is to work with engineers to develop solutions for Yamaha’s customers, but he also looks for compatible technologies that enhance the use of Yamaha’s products.
Initially, Schauer used the wireless extender during sales staff and dealer trainings to demonstrate how simply audio can be controlled without an intricate setup. “We wanted to avoid having a ‘snake’ cable that sends all the inputs to and from the stage to the mixer, allowing for a quicker, cleaner setup,” he said.
Demonstrations included the Yamaha 01V96 digital mixing console, a Presonus Digimax LT Microphone preamplifier/digital interface, a Dell Latitude D820 laptop and an Apple MacBook Pro.
The Gefen Wireless USB Extender was selected primarily because of its simplicity. “One of its best features is the easy setup,” said Schauer. “The solution is completely transparent, and stability and security of the wireless link has not been an issue. The connection is very robust.”
On the road installations require a robust solution that is easy to use and simple to install. Schauer also required a high degree of reliability. “It needed to function out in the world with lots of other RF interference and still retain its connectivity.”
Schauer also tested the Gefen Wireless USB Extender in a real-world environment with a local band that controls their on-stage mixer using a PC located sixty feet from the stage.
“It is a very elegant, simple solution that gives our customers the chance to operate their digital audio console from a position out in the audience without all the wiring required by conventional means,” said Schauer. “We are very satisfied with the Wireless USB Extender from Gefen, and will benefit as more of our digital mixers find their way into situations where portability, ease of setup, reliable operation and the ability to be wireless are key.”
About Gefen:
Gefen delivers advanced technologies with multi-platform extension, switching, distribution and conversion capabilities. Gefen equipment is valued around the world in professional A/V, information technology and consumer electronics/home theater environments. Their add-on hardware maximizes functionality by enabling systems to operate beyond their original capabilities. A selection of high quality cabling is also available. Visit www.gefen.com for detailed product information.
About Yamaha Corporation of America:
Yamaha Corporation of America is the largest subsidiary of Yamaha Corporation, Japan and offers a full line of musical instruments and sound reinforcement products to the U.S. market. Products include: acoustic and digital pianos, portable keyboards, guitars, acoustic and electronic drums, band and orchestral instruments, marching percussion products, synthesizers, professional digital and analog audio products, and innovative technology products targeted to the hobbyist, education, worship, professional music, and installation markets.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
