Gefen ToolBox HD 1080p Scaler
Gefen introduced a solution for integrating audio/video systems using displays with different native resolutions. The Gefen ToolBox HD 1080p Scaler will automatically scale up or down any high definition signal to meet the maximum resolution supported by the connected HDTV display.
When used in an installation with more than one display in the room, such as in digital signage or home theater, it allows 1080p resolutions to be viewed on displays with 1080p full HD capability, while scaling the lower resolution display to its maximum resolution.
For example, when sending a hi-def signal to four displays, one display may support 720p maximum resolution, while the other three displays support 1080p full HD. Previously, installers would have to set the source to 720p, the lowest common resolution among all four displays, to ensure a seamless distribution. But when the HD 1080p Scaler is connected to the 720p display, it will accept a 1080p input and downscale it to 720p, while all other displays receive 1080p full HD.
In a home entertainment scenario, you might have a 720p projector and 1080p display both connected to the same audio/video source. In this case, the HD 1080p Scaler can be connected to the projector to automatically downscale the signal to 720p, while the display will receive a full HD signal.
All video resolutions can also be manually scaled up or down to accommodate any type or size display using HDMI.
Three switchable digital audio inputs and outputs support coax, optical and HDMI devices. You can input coax or optical audio and bypass the HDMI audio or output it as HDMI audio; you can input HDMI audio and output it as coax, optical and HDMI. All three audio outputs are live. Users select their audio using the menu button, RS-232 or IR remote.
How it works
Use the included HDMI cable to connect the source to the High Definition 1080p Scaler. Connect the display to the Scaler using an HDMI cable. Connect an optical and / or coax audio cable from the source to the Scaler. Another set of optical and / or coax audio cables can be connected to an A/V receiver or amplifier. Connect the 5V DC locking power supply to the Scaler and connect the power cord to an available electrical outlet. Select the audio input by using the On-Screen Display with the front panel buttons or the included IR remote control.
HDMI Features Supported:
  • 1080p Full HD
  • Deep Color
  • Dolby TrueHD and DTS-HD Master Audio
  • Lip Sync
Price and Availability
The Gefen ToolBox HD 1080p Scaler is available now in black or white for $329.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
