Gefen One of the First to Introduce Cable-Only Apple HD Cinema Display Extension Solution
WOODLAND HILLS, CA – September 30, 2004 – Two new extension solutions from Gefen make extending Apple’s new 20 and 23 inch HD Cinema Displays an easy affair. Three cables are bundled together and capped on each end by three connectors: DVI, Firewire and USB. The 10 and 15 foot cable-only solutions require no hardware or external power to operate.
Gefen’s combo cable requires a simple connection to the computer on one end, and to the extended display and peripherals on the other end. For longer lengths, Gefen provides a variety of extender kits that support long distances, up to hundreds of meters in length.
Extending displays and peripherals away from the computer is desired for many reasons, most notable being the need for a quiet work space, achieved by isolating the computer to avoid the noise of the computer fans.
The 10 foot ($99) and the 15 foot ($129) extension cables are currently available through Gefen’s website (www.gefen.com) or a Gefen dealer, listed online.
About Gefen Inc:
Gefen provides computer and electronics connectivity solutions through its ex-tend-it Professional Series, which offers multi-platform extension, switching, distribution and conversion technologies. Gefen’s new HDTV solutions split, switch, convert and extend high definition digital video. SDI, HDMI, fiber optics, DVI and CAT5 solutions are also available through Gefen as well as a variety of cabling.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
