Gefen DVI-3500 KVM Extension Solution
Connectivity solutions provider Gefen today announced the availability of its new DVI-3500HD. This long-range sender/receiver extension system delivers video in the DVI format with USB peripherals, RS-232 control and analog audio up to 6600 feet (2 kilometers) in distance over fiber optic cables. The DVI-3500HD supports extended resolutions up to 1920×1200.
A unique feature of the Gefen DVI-3500 HD is the ability to operate in either local or remote mode. When in local mode, the DVI display and USB peripherals connected at the computer’s location can be used to access data; when in remote mode, the DVI display and USB peripherals connected at the extended location can be used to access data. Essentially, two different locations can access the same computer, giving always available access to mission-critical data. A front panel switch on the sender unit allows users to select local or remote mode.
Installation of the DVI-3500HD is a simple matter, requiring the computer to be connected to the sender unit’s DVI, audio USB, audio and RS-232 connectors; local DVI display and USB peripherals such as keyboard/mouse can be connected here for local access. The extended display connects to the receiver unit along with the USB, audio and RS-232 peripherals. Fiber optic cables connect the local sender unit to the remote receiver unit, presenting an instant, long range transmission of computer signals when in remote mode. The fiber cable can be single or multi-mode 62.5 or 50 microns and the connectors are LC to LC type.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
