Connectivity solutions provider Gefen today announced the availability of two new plug and play methods of system integration among computer systems using DisplayPort connectivity.
DisplayPort KVM Switcher
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8689
This KVM (keyboard, video, mouse) switcher offers a simple method of accessing any two computers from the same display, with the same USB 2.0 keyboard/mouse control. It saves space on the desktop, creating a more productive work environment. Switching between computers takes place using the IR remote or front-panel selector. Support for high definition video resolutions, hi-speed USB 2.0 peripherals and an audio output makes it ideally suited for today’s computer systems.
DVI to Mini-DisplayPort Adapter
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8913
This adapter is designed for computer users who want to use a standard DVI port to connect a new flat panel display using mini-DisplayPort connectivity, such as the 24-inch Apple Cinema Display. The DVI to Mini-DisplayPort Adapter can be used to connect a second display in mirrored mode to extend the desktop. This new Adapter joins Gefen’s existing DisplayPort accessories, such as the Mini-DisplayPort to DVI Adapter, currently available. Both adapters support high definition resolutions at 1920×1200 @60Hz and come packaged in a small enclosure for easy installation.
