HDTV 4K & 8K TV
Gefen Discounts HDTV Extreme Cables for High Definition Video Extension
WOODLAND HILLS, CA — April 8, 2005 — Gefen announced that it has discounted its HDTV Extreme cables, now available in 33, 50, 66, 75, 100, 135, 210 and 330 foot lengths. HDTV Extreme cables are uniquely suited for HDTV projection and computer video extension because they combine fiber optics components and copper wires in a single cable in which the electronics are part of the DVI connectors.
Sending the high resolutions of high definition video beyond 15 feet from the computer or satellite set-top box to the display requires the proper cabling and transmission techniques. Using an off-the-shelf cable may work for some systems but those who demand high resolution often experience video pixilation that deteriorates the further the display is extended.
“By making fiber DVI cables cost similar to the price of DVI copper cables, we can offer unparallel video quality to 1080p,” said Hagai Gefen, president. “You can go as far as 300 feet from the source using one convenient DVI-equipped cable.”
Most flat panel displays manufactured today, including Apple’s new Cinema Displays, are equipped with DVI to connect the display to the source.
Gefen’s HDTV Extreme cables are currently available online at www.gefen.com or through a Gefen reseller.
http://www.gefen.com/kvm/cables/hdtv_dvi.jsp#hdtvextreme
Gefen provides consumer electronics and audio/video connectivity solutions with multi-platform extension, switching, distribution and conversion capabilities. Gefen is consistently the first to deliver advanced technologies for home theater, computers and other AV environments. Products support high definition digital video, analog video and digital and analog audio using various interfaces such as HDMI, DVI, dual link DVI, HD-SDI, SDI, VGA, USB, Firewire and RS-232. A selection of cabling is also available. Additional information may be found at www.gefen.com.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
