Gefen Announces Audio Solutions to Maximize Systems at Macworld
For those wanting to listen to their iTunes, DVD players or CD players on their existing analog stereo system, the GefenTV Digital Audio Decoder with Dolby is the solution. Up to 5.1 channels of digital audio in Dolby Digital Surround sound is converted to the analog two-channel (left/right) format using this plug and play decoder. It accepts digital audio in both TOSlink and S/PDIF formats, converting it to L/R analog audio that connects directly to your existing powered speakers for rich, two-channel sound. A tiny switch on the Decoder selects either the S/PDIF or TOSlink format. There is no need to purchase additional audio equipment when you can utilize your existing audio system to enjoy the best digital music available today, with support for the Dolby Digital format.
GefenTV is also showing a 2×1 Digital Audio Switcher, which allows you to connect two CD players, DVD players or computer audio systems to one A/V receiver using the TOSlink format. Users switch between both digital audio sources using the tiny switch on the Switcher. For added convenience, all three digital audio devices (two sources; one receiver) may be connected up to 25-feet in distance using standard TOSlink cables.
The GefenTV 1:2 Digital Audio Splitter streamlines audio systems by allowing one CD player, computer system or DVD player to deliver audio to two different A/V receivers at the same time. This tiny solution accepts one digital audio signal in TOSlink format and delivers two TOSlink outputs. For multi-zone audio environments, this is the perfect solution. One audio input and two digital audio outputs can be connected up to 16-feet in distance for flexibility in system set-up.
About Gefen:
A leader in the high definition digital domain, Gefen provides advanced solutions for Macintosh users that extend, integrate, optimize, distribute and convert HD and PC signals to maximize system functionality. The GefenTV brand offers pro-quality engineering streamlined for consumers. Gefen’s add-on solutions enhance computer systems by allowing them to operate beyond their original capabilities. A selection of high quality cables complements the product line. Visit www.gefen.com for detailed product information.
Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
Sharp TIVO TV Lifestyle Man View Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
