Furutechs Top Performance e-TP309 AC Power Distributor
The e-TP309 AC Power Distributor
Features Axial Locking System and EMI-Absorbing Formula GC-303
7/20/09 • Tokyo, Japan • Furutech Co., Ltd., manufacturer of ultra refined analog, digital, video cable and accessories, announces the e-TP309 AC Power Distributor that joins their full line of power distribution and filtering products.
The e-TP309 is a sophisticated, luxuriously made power distributor of almost unbelievable quality that eliminates many problems caused by poor connections, contact resistance, EMI, RFI, and lack of resonance control.
It’s All About the Receptacles
All enthusiasts are looking for the same qualities: Verisimilitude to the original event, a sense of engagement promoting suspension of disbelief, an immersion in audio and video experience. To engage without effort requires meticulous preparation of the entire playback chain especially including the AC power.
Central to the e-TP309’s success at controlling resonances are the extreme high performance Furutech Pure Transmission AC receptacles. They feature nonmagnetic rhodium-plated Alpha phosphor bronze fittings over a nylon/fiberglass body that incorporates carbon particles in the manufacture. This industrial recipe creates an extremely effective nonresonant connector body.
With a further eye to resonance control and tight, secure connections, the ‘309 is equipped with resonance-damping material around each receptacle that’s “set” against the bottom plate with a patented Axial Locking Screw. It’s hand-torqued at the factory and measurably reduces receptacle resonance by a factor of ten!
The ‘309 is wired with Furutech Alpha 10 conductors–5.5 sq. mm 10 AWG–ensuring very low electrical resistance, and the star-wired conductors are sheathed within resonance-absorbing tubing. There’s also a layer of Formula GC-303 bonded to bottom plate that effectively shields against EMI (Electro Magnetic Interference).
Naturally the chassis is made of the highest-grade aluminum to effectively shield against RFI (Radio Frequency Interference). Befitting a unit of such style and effectiveness, it’s equipped with a beautifully-crafted aluminum top plate dressed in an elegant carbon fiber finish.
Formula GC-303
GC-303 is a special material Furutech bonds to the interior bottom-plate of the chassis that absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit.
Furutech’s Patent-Pending Axial Locking System
Furutech designed a special locking screw that anchors each duplex receptacle preventing oscillation and enhancing long-term stability. A special 3M material surrounds and isolates each duplex outlet from resonance as well. Each Axial Lock is torqued to perfection to work with the 3M resonance control material at the factory.
The Furutech e-TP309 features nonmagnetic rhodium-plated Alpha phosphor bronze fittings and nylon/fiberglass bodies that incorporate carbon particles for resonance damping. The IEC features rhodium-plated Alpha pure-copper fittings, plus the remarkable Axial Locking System and anti-EMI Formula GC-303 bonded to the bottom plate. All conductors are star-wired with Alpha 10, 5.5 sq. mm (10 AWG) surrounded by resonance-absorbing tubing.
The chassis is fabricated from the highest-grade aluminum with an attractive carbon fiber-finished top plate. All conductors treated with Furutech’s Alpha Cryogenic and Demagnetizing Process.
Furutech’s Award-Winning Pure Transmission Build Quality
Many A/V enthusiasts go to great lengths to carefully set up major system components, but pay little attention to the source, the AC power. Meticulous build quality is a large part of the engineering equation.
About Furutech
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power connectors and parts, as well as distribution/filtering products like the new 120Hz standard xv1.3 HDMI cable, Ag-12 Silver Tonearm Cable, Pure Power 6, e-TP4+4, e-TP609 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the deStat, a fan-driven, Balanced Ion Drive device for totally eliminating static from LPs and CDs, DF-2 LP Flattener, lightweight and stylish FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and their own very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
Make a More Powerful Connection with Furutech!
FURUTECH CO., LTD • service@furutech.comwww.furutech.com
Press • Info • Review • Images • Scull Communications • 212.807.0519
jscull@scullcommunications.comwww.scullcommunications.com
www.scullcommunications.com/pressresources.html
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
