Furutech Monza LP Stabilizer
Grand Prix Technology for Your Valued Vinyl
Furutech Co., Ltd., manufacturer of analog and digital audio and video cable and accessories, is is delighted to unveil the new Monza LP Stabilizer; Pure Transmission technology for your valued vinyl.
La Grande Epreuve
Grand Prix racing’s single focus: Testing the absolute limits of technology and performance for that final 10th of a second that makes the difference between victory and also-ran. Furutech builds each and every cable in their line the same way; optimized engineering solutions applied to advanced materials and processes, backed by utterly meticulous build quality.
The beautifully finished precision machined nonmagnetic stainless steel base and top modules are separated by a layer of damping carbon fiber. The bottom surface is covered with 16 concentric cushioning grooves made of an extremely effective Piezo Electric damping material.
The Piezo Effect and Your Valued LPs
Furutech’s Pure Transmission Piezo Ceramic Carbon series products–like the Innovations award-winning FI-50 connector series–feature remarkable “active system” technology. We create a unique material mixing two “active” materials: Nano-sized ceramic particles and powdered carbon. Only nano-sized ceramic particles effectively couples with carbon powder for the piezo effect to occur. Nylon and fiberglass are incorporated into the mix as well, and the whole forms an extremely effective mechanically and electrically damped material. That’s not a misprint; it’s electrically damped as well.
Piezoelectric effects are the key. Furutech employs nano-sized polycrystalline ferroelectric ceramic particles exhibiting electro-generative properties (mechanical pressure creates an electrical charge) with carbon powder that exhibits thermal-conductive characteristics that interacts with the electrically charged ferro-ceramic particles converting their energy into heat that’s conducted away and released from the surface of the material, and in doing so making the connection between electrical and mechanical oscillation. The mechanical and electrical damping effects occur while “interconverting” thermal, mechanical, and electrical energy, the perfect weighted surface for your LPs!
MSRP $480 * Available Now!
Furutech was honored with a Best of Innovations 2009 award for what may be the most sophisticated and thoroughly engineered AC connectors in the world, the FI-50 Series, now standard equipment on the Furutech Piezo Powerflux AC cord.
Furutech make other award-winning analog accessories like the DF-2 LP Flattener, the celebrated DeMag, the DeStat, the SK-II LP Brush, and the Ag-12 Phono Cable of which Michael Fremer of Stereophile recently wrote: “The award for best performance and highest build quality at the lowest price goes to the Furutech AG-12.”.
About Furutech
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power connectors and parts, as well as distribution/filtering products like the new 120Hz standard xv1.3 HDMI cable, Ag-12 Silver Tonearm Cable, Pure Power 6, e-TP4+4, e-TP609 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the deStat, a fan-driven, Balanced Ion Drive device for totally eliminating static from LPs and CDs, DF-2 LP Flattener, lightweight and stylish FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and their own very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
