Furutech FTP-615 Power Filter/AC Distributor
New for 2009!
FTP-615 Power Filter and AC Distributor
Featuring Axial Locking System and EMI-Absorbing GC-303
MSRP: $700 • Shipping 2nd Week of January ’09
Tokyo • December 22nd, 2008 • Furutech Co., Ltd., manufacturer of analog and digital audio and video cable and accessories, debuts another Pure Transmission Power Filter and AC Distributor, the
FTP-615.
Features
• All conductors treated with Furutech’s Alpha Cryogenic and Demagnetizing Process
• Nonmagnetic 24k gold-plated Alpha phosphor bronze Pure Transmission receptacles feature nylon/fiberglass bodies incorporating nano-size ceramic particles forming an extremely effective nonresonant body
• Furutech’s Axial Locking System lowers receptacle resonance by a factor of 10
• AC-1501 noise-filter inlet features 24k gold-plated Alpha brass conductors
• Beautifully-crafted highest-grade aluminum chassis effectively shields against RFI (Radio Frequency Interference)
• Layer of Formula GC-303 bonded to the bottom plate effectively shields against EMI (Electro Magnetic Interference)
• Star-wired conductors of Furutech Alpha)-22, 3.8 sq. mm (12 AWG) for low electrical resistance insulated inside resonance-absorbing tubing
Furutech Award-Winning Pure Transmission Philosophy
Many A/V enthusiasts go to great lengths to carefully set up major system components, but pay little attention to the source, the AC power. Meticulous build quality is a large part of the engineering equation. Furutech Pure Transmission technology turns a macro lens on every element of power and signal transfer applying optimized engineering solutions to well-known problems such as contact resistance, EMI and RFI rejection, grounding, and using the best materials and processes available.
Formula GC-303
GC-303 is a special material Furutech bonds to the interior bottom-plate of the chassis. that absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit.
Interior Layout
The image below Illustrates the FTP-615’s AC-1501 Power Filter and full star wiring on hot neutral and ground running in resonance-damping tubes for maximum isolation.
C:Documents and SettingsAdministratorMy Documents�0 Scull Communications�0 Furutech�0 FTP 615Additional Imagesfuru_ftp615_interior.jpg
Furutech’s Patent-Pending Axial Locking System
Furutech designed a special locking screw that anchors each duplex receptacle preventing oscillation and enhancing long-term stability. A special 3M material surrounds and isolates each duplex outlet from resonance as well. Each Axial Lock is torqued to perfection to work with the 3M resonance control material at the factory.
C:Documents and SettingsAdministratorMy Documents�0 Scull Communications�0 Furutech�0 FTP 615Additional Imagesfuru_axial_lock_615_ec.jpg
Axial Locking Reduces Noise, Oscillation and Vibration By Nearly A Factor of Ten!
About Furutech
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power connectors and parts, as well as distribution/filtering products like the new 120Hz standard xv1.3 HDMI cable, Ag-12 Silver Tonearm Cable, Pure Power 6, e-TP4+4, e-TP609 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the deStat, a fan-driven, Balanced Ion Drive device for totally eliminating static from LPs and CDs, DF-2 LP Flattener, lightweight and stylish FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and their own very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
Make A More Powerful Connection with Furutech!
FURUTECH CO., LTD • service@furutech.comwww.furutech.com
Press • Info • Review • Images • Scull Communications • 212.807.0519
jscull@scullcommunications.comwww.scullcommunications.com
www.scullcommunications.com/pressresources.html
Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
Bang & Olufsen Beosound Balance Natura Wireless Speakers Bang & Olufsen Beosound Balance Natura Wireless Speakers
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
Advance Paris Link Cables Advance Paris Link Cables
Audio Cables
High-end cables made in France? Do British and American manufacturers need to be concerned? The Advance Paris LINK have us excited to try them.
https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player https://www.audioadvice.com/products/kaleidescape-strato-c-4k-ultra-hd-movie-player?referral=ecoustics Strato M Movie Player
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Sony's new 2025 model year BRAVIA TVs Sony's new 2025 model year BRAVIA TVs
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
Sony BTAVIA Projectors - 2025 Sony BTAVIA Projectors - 2025
Sony just brought its most powerful video processor for projectors down to what should be a much more affordable price point.
