Furutech DFV-1 Flattens Warped LPs!
Furutech DFV-1Furutech debuts the ultimate LP flattener, the DFV-1. Every vinyl enthusiast has records in their collection that they wish were a bit less warped. The DFV-1 is the one-stop, one-button solution to your problems! Using a carefully controlled heating and cooling cycle it flatten all your warped records, even those with only slight irregularities that still unsettle your cartridge causing mistracking.
Warps And Listening
Warps are detrimental in every way. If the arm/cartridge remains parallel to the LP’s surface as when playing a flat record, VTA (Vertical Tracking Angle) remains unchanged during play. Additionally, as the arm/cartridge tracks a warp on its upside, greater pressure is placed on the stylus which changes VTF (Vertical Tracking Force) until the peak of the warp, whereupon the cartridge “unloads” with too little VTF on the way down the slope of the warp. This muddles the sound, changes the tonal quality, imaging and soundstage characteristics of any cartridge. A flat record tracks better with less distortion.
The DFV-1 takes up little room with its space-saving, vertical design! Improved film heating technology optimizes the entire heating and cooling cycle for a perfectly flat LP that you and your cartridge will love. Just unlock and open the DFV-1, place the LP on the spindle, close and tap a single button. An LCD keeps you informed of progress with a tone sounding when done. Right from the oven to your platter!
DVF-1 Record Flattener – One-Stop, One-Button Solution For Warped Records
MSRP: $1,480.00 — Available: Now
DFV-1 Specifications
  • Rating: 117V±10% 60Hz AC Line 2A fuse
  • Energy Consumption: 170W (max) 35W (Norm)
  • Heating plate max. temp: 65
  • Size: 480mm/19″ W x 544mm/21.5″ H x 17mm/7″ D
  • Weight: 11kg/24lbs approx.
  • Safe Usage Environment: Humidity 20% – 90% (No condensation)
  • Manufactured for Furutech by ORB High End Systems of Japan
All metal parts treated with Furutech’s α Alpha Cryogenic & Demagnetizing Process
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
