Furutech Daytona 303 Multi-Mode AC Filter/Distributor
Features Resonance-Damped Receptacles and Locking Plates & EMI-Absorbing Formula GC-303
Furutech Co., Ltd., manufacturer of ultra refined analog, digital, video cable and accessories, pulls the cover off the e-TP303 Daytona Multi-Mode AC Filter/Power Distributor, providing comprehensive protection and filtering for your audio or home theater system.
The Daytona: 24 Hour Protection for Pro A/V and High Performance Enthusiasts
The Daytona is designed for professional installers working with high-end home entertainment systems, recording and touring venues, and high performance home enthusiasts.
We’re all looking for the same qualities: Verisimilitude to the original event, a sense of engagement promoting suspension of disbelief, an immersion in audio and video experience. To engage without effort requires meticulous preparation of the entire playback chain especially including the AC mains supply.
The Daytona 303 is a sophisticated, luxuriously made single-chassis power distributor and filtering unit that eliminates many common problems caused by massively contaminated electrical power lines. The AC mains waveform is heavily distorted by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise radiating from processors and digital interconnects.
There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in small electronics and charging devices on the same circuit. Additionally, you’re never alone; your residential AC supply is shared with other apartments, homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
Under the Hood
Like a Daytona GT racer, the Furutech e-TP303 is purpose-made to comprehensively protect your audio and video system with 5250 joules of surge protection plus Stage 3 filtering that dramatically reduces induced, radiated and ground-borne noise. Micro-circuits monitor line voltage and disconnects instantly if dangerous over- or under-voltages occurs, then reconnects once the power returns to safe levels.
The Daytona also features three ultra-advanced isolating filter sections including two analog, two digital, plus another pair of ultra-high-current audio filters. The Daytona also sports 12 surge-protected AC outlets, 3 pair of protected coaxial connections, and 1-in/2-out fully-protected phone line connections.
On the Track
The Daytona 303 relieves your system of flat, hard, and grainy high frequencies, a thick and bloated midrange over wooly bass, a loss of air, detail and soundstage instability. On video displays the picture resolution is sharper, with no ghosting, color shift, snow, or vertical and horizontal lines to spoil the view. If this sounds familiar, you need a Furutech Daytona 303!
Features
The Daytona 303 features four unfiltered outlets: Direct 1 for Power amplifiers and Direct 2 for Preamplifiers and analog devices. There are six digital filtered outlets: Filter 1/Zone 1 for DVD and DVR, Filter 2/Zone 2 for CD, cable and SAT, and Filter 3/Zone 3 for TVs and projectors. All Furutech Pure Transmission receptacles feature nonmagnetic rhodium-plated Alpha phosphor bronze fittings.
The Daytona is beautifully-crafted of the highest-grade aluminum panels with a painted steel chassis that effectively shields against RFI (Radio Frequency Interference). A layer of EMI-absorbing Formula GC-303 bonded to bottom plate effectively shields against EMI (Electro Magnetic Interference). Internal wiring is Furutech Alpha-10, 5.5 sq. mm (10 AWG) for low electrical resistance, and all conductors are insulated with resonance-absorbing tubing
The front panel has eight indicators for abnormal operation including abnormal voltage, filter 1, 2, 3/zone 1, 2, 3, correct path, breaker, digital voltage and digital amperage meter. The rear panel features an attachable LED lamp so you can see what you’re doing, three sets of surge-protected coaxial terminals, surge-protected 3-way phone connections, remote control triggers, a sequence switch, and a voltage selector switch for 120V AC (60Hz) or 100V AC (50/60Hz)
standard rack mounting plates. All conductors are treated with Furutech’s Alpha Cryogenic and Demagnetizing Process
About Furutech
Furutech makes a wide variety of high performance 15A and 20A A/V cable and power connectors and parts, as well as distribution/filtering products like the new 120Hz standard xv1.3 HDMI cable, Ag-12 Silver Tonearm Cable, Pure Power 6, e-TP4+4, e-TP609, e-TP619 and e-TP60 Power Distributors, and e-TP80 Power Filters, deMag Disc and Cable Demagnetizer, the deStat, a fan-driven, Balanced Ion Drive device for totally eliminating static from LPs and CDs, DF-2 LP Flattener, lightweight and stylish FRD Room Diffusion Panels, PC-2 Disc Pure Cleaner, and their own very special NANO Liquid Contact Enhancer, plus even more fine cable and OEM products.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
