Mirrorless Cameras
FujiFilm X-E1 Interchangeable Lens Camera
FUJIFILM X-E1
FUJIFILM announced the compact X-E1, a premium interchangeable lens digital camera system that uses the same proprietary 16.3 Megapixel APS-C X-Trans CMOS sensor and X-Mount for use with FUJINON XF lenses as their X-Pro1, but in a body that is 30% smaller. Fujifilm claims their advanced X-Trans CMOS sensor is capable of delivering resolution that is superior to other APS-C sensors, and equal to even some full frame sensors found in popular DSLR cameras.
The FUJIFILM X-E1’s unique color filter array can effectively minimize moire and false color without the need for an optical low pass filter. This makes it possible for the camera to maximize its extremely high resolution, and to capture each photograph with accuracy and clarity across the whole image.
FUJIFILM original “X-Mount” maximizes lens performance
Specifically designed to take advantage of the camera’s mirrorless design, the X-Mount has a short flange back distance of just 17.7mm made possible by designing the mount ring as thin as 2.5mm. This means the rear lens elements are as close as possible to the sensor, reducing the back focus distance of each lens to the minimum possible, thus achieving high resolution from edge to edge. And when fitted with a FUJIFILM M Mount Adapter, the X-E1 can use a wide variety of M lenses to broaden the scope of your photography.
FUJIFILM X-E1 - back
2.36 million dot “Organic LED (OLED) electronic viewfinder”
The FUJIFILM X-E1 camera comes equipped with a high definition, high luminance OLED electronic viewfinder with a resolution of 2.36 million dots that is one of the highest resolutions available on an EVF-equipped digital camera today. The natural, bright viewfinder offers a horizontal field of view of 25-degrees, allowing users to scan the entire scene quickly and easily.
Premium quality design and portability
Made in Japan, the X-E1 exudes precision, elegance and premium quality that can be seen from each of its components. The top and front covers are made from die-cast magnesium for a solid, yet functional design. At roughly the same size as the FUJIFILM X100, the X-E1 is refreshingly compact and lightweight (12.35oz). Featuring a rubber grip for additional stability, and with the X-Mount positioned centrally on the camera, the X-E1 is perfectly-balanced.
FUJIFILM Fujinon Lenses
New XF14mm (21mm) F2.8 single focal length lens and XF18mm-55mm (27-84mm) F2.8-4 lens
The FUJIFILM X-E1 pairs perfectly with the XF18mm-55mm (27-84mm) F2.8-4 lens to deliver super-fast focusing speeds that will capture even the fastest action. The highly responsive linear motor in the XF18-55mm lens combines with the high-speed signal readout of the X-Trans CMOS sensor and the EXR Processor Pro, to achieve a huge leap in AF speed and precision performance. Contrast Detection in the X-E1 brings your subject into sharp focus in as little as 0.1 seconds.
A true masterpiece of optical technology, the high quality all-glass lens structure consists of 14 elements in 10 groups, including 3 aspherical lenses and 1 extra low dispersion element, as well as a seven-blade rounded diaphragm. This zoom lens covers a broad range of frequently-used focal lengths from 18mm in wide angle to 55mm mid telephoto (35mm  equivalent: 27mm to 84mm) to capture everything from landscapes to street photography.
At F2.8-4 wide open, this fast lens is perfect for low-light photography or scenes beckoning a beautiful bokeh effect. Advanced optical and mechanical designs are optimized to keep the lens compact, while maintaining a physical aperture ring so that users can make fluid adjustments. The lens also features OIS to provide image stabilization equivalent to 4 stops, controlling the effect of camera shake and allowing users to seize perfect photo opportunities.
The new FUJINON XF14mm (21mm) F2.8 single focal length lens offers a stunning, ultra wide angle that delivers exceptional resolution from edge to edge. The new lens consists of 10 elements in 7 groups, including 2 aspheric and 3 extra low dispersion elements, and a seven-blade rounded diaphragm.
With its distance and depth of field scales on the barrel, the FUJINON XF14mm (21mm) F2.8 lens is ideally suited for a range of shooting techniques. And with its bright, F2.8 aperture, the lens performs beautifully in low-light shooting.
FUJIFILM X-E1 - top
Diverse shooting modes
The X-E1 offers Fujifilm’s creative “Film Simulation Modes” to simulate the distinctive color palates of conventional photo film. Film Simulation Modes include “Velvia,” “ASTIA,” and “PROVIA,” as well as two additional settings based on professional color negative films, PRO Neg.Std and PRO Neg.Hi.
In addition, advanced digital processing in the X-E1 enables multiple exposures, giving photographers the ability to take two shots while visually checking the finished image, either in the viewfinder or LCD screen.
Full HD Movie recording
The X-E1 supports shooting Full HD movies (1920×1080) at 24fps. In addition, you can now use Monochrome or Film Simulation modes when video recording and even take advantage of the X-E1’s large sensor and bright XF lenses to capture movies with beautiful bokeh effect. Connect a stereo microphone (3rd party sold separately) to the external microphone input and record audio with enhanced clarity.
[youtube id=”5dyJixwqNoY” width=”610″ height=”373″]
[youtube id=”Rr0G1yVl48c” width=”610″ height=”373″]
[youtube id=”26zDJYV_iWg” width=”610″ height=”373″]
XE-1 Features:
  • 16.3 megapixel APS-C X-Trans CMOS Sensor and EXR Processor Pro
  • FUJIFILM X-Mount
  • Extra high resolution 2.36 million dot Organic OLED viewfinder
  • 2.8-inch (460K dot) LCD
  • Built-in pop-up TTL Flash
  • ISO100 – 25600 (range of ISO200-6400 when using ISO Auto)
  • Q Menu shortcut button
  • In-camera RAW converter
  • Film simulation modes (Velvia, ASTIA, PROVIA, Monochrome, Sepia, PRO Neg.Std & PRO Neg.Hi)
  • Multiple exposure and panoramic shooting modes
  • Auto Bracketing functions (AE/ISO/DR and FS)
  • Full HD Movie (1920×1080)
  • Approximately 350 shots per battery charge
FUJINON XF14mm Features:
  • 21mm equivalent bright F2.8 lens
  • Consists of 10 elements in 7 groups, including 2 aspheric and 3 extra low dispersion elements and a seven-blade rounded diaphragm
  • 58mm lens filter size
FUJINON XF18mm-55mm key features list:
  • 27-84mm equivalent F2.8-4 lens
  • Highly responsive linear motor
  • Contrast Detection brings subject into sharp focus in as little as 0.1 seconds
  • High quality all-glass lens structure consists of 14 elements in 10 groups, including 3 aspherical lenses and 1 extra low dispersion element, as well as a seven-blade rounded diaphragm
  • OIS to provide image stabilization equivalent to 4 stops
Accessories available for the FUJIFILM X-E1:
  • High quality leather half case
  • FUJINON XF Lenses (3 available and 2 announced today, 10 total by end of 2013)
  • M Mount Adapter
  • Ergonomically designed hand grip
  • Three dedicated flash models to choose from depending on requirements (EF20, EF40, EFX20)
  • Protector filters (39mm, 52mm, 58mm)
  • Remote release cable (RR-80)
Pricing and Availability
  • The FUJIFILM X-E1 (body only) will be available in November 2012 for $999.95.
  • The FUJIFILM X-E1 and XF18mm-55mm (27-84mm) F2.8-4 lens (kit) will be available in November for $1,399.95.
  • The FUJINON XF14mm (21mm) F2.8 single focal length lens will be available in November for $899.95.
  • FUJINON XF18mm-55mm (27-84mm) F2.8-4 lens will be available in November for 699.95.
For FUJIFILM X-Pro1 and X-E1 customers
Please update the firmware of your camera body when using the XF18-55mm and XF14mm lenses for the first time. The firmware will be supplied by SD card (bundled in 18-55mm and 14mm Lens Boxes) or can be downloaded from “Support” on the Fujifilm Global website. It will be available in two classic designs: a two-tone black and silver, and a solid black. Both versions of the X-E1 will also ship as kits with the XF18mm-55mm (27-84mm) F2.8-4 lens in November 2012. See http://www.fujifilm.com/support/digital_cameras/ for details.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
