High Performance Meets High Definition with Powerful Zoom Range and Cutting-Edge HD Capabilities
FUJIFILM North America Corporation just announced two new additions to its S-Series line: The FinePix S1800 and FinePix S2550HD. Sporting a 12-MegaPixel 1/2.3″ CCD, a powerful Fujinon 18x Wide-Angle optical zoom (28mm-504mm equivalent) and an extra large 3.0″ High-Contrast LCD and electronic viewfinder, the FinePix S2550HD is perfect for advanced amateur photographers who want an affordable, step-up digital camera that will still fit in the palm of their hand.
HD Movie Capture
The S2550HD can capture movies in 720p HD quality and has a mini HDMI Port for quick and easy connection to a home theater system. The S2550HD can also use Fujifilm’s optional HD Player Kit — which includes an HD Card Reader that connects to your HDTV via HDMI Cable for true digital transfer of HD quality and a wireless Remote Control for video playback from the comfort of your couch — and you maximize your HD experience.
“With the rapidly increasing adoption of HDTV, consumers have changed how they use their digital photographs and movies,” said David Troy, marketing manager, Consumer Digital Cameras, Electronic Imaging Division, Fujifilm North America Corporation. “Fujifilm’s superior image quality with the FinePix S2550HD enables the user to capture still images and shoot video in true HD and realize the benefit of superior image quality and long zoom capabilities with their home entertainment system.”
18x Fujinon Optical Zoom Lens
The S2550HD features a Fujinon 18x Wide-Angle optical zoom lens that produces crisp high resolution results throughout the focal range, from 28mm wide-angle to an astounding 504mm telephoto. They also feature Instant Zoom, which enables the user to keep their subject in a shot at long distance by offering a wide viewing area around the frame and then immediately cropping to the subject once the photo is taken.
Smile and Blink Detection
In addition to Fujifilm’s signature Face Detection, Fujifilm has added two fun and valuable features: Smile Detection recognizes the precise moment your subject smiles and releases the shutter only when this happens; and Blink Detection warns you if any of your subjects have blinked so that you can re-take the photo if necessary.
Image Retrieval
Fujifilm has created a new Picture Search tool which allows you to find photos quickly and easily. You can search with both digital cameras by whichever Scene Mode the photo was taken. For instance if you select ‘Portrait,’ you can view all photos shot in Portrait mode, or ‘Macro’ to see all close up shots…etc. It’s a time saving feature which means that you will no longer have to waste time searching through all your photos to find the ones you are looking for.
The FinePix S2550HD additional features:
- 3.0″ High-Contrast LCD and Electronic View Finder: High contrast 230K-pixel 3.0″ LCD and Electronic View Finder. The high contrast LCD is a considerable benefit in bright light and means that the camera can be pitched at various shooting angles to enable framing of awkward shots, while the Electronic View Finder provides even more flexibility for the user.
- Dual Image Stabilization: Long-zoom cameras need stabilization more than any other compact, with handshake and subject movement a particular problem in low light at telephoto range. The S2550HD reduces blur to a minimum with a mechanically stabilized CCD sensor and high ISO sensitivity (to ISO 6400), so that blur is reduced to an absolute minimum.
- Face Detection and Automatic Red-eye Removal: To provide perfectly exposed and focused portrait shots, the S2550HD is fitted with Fujifilm’s latest Face Detection technology which is able to track up to 10 faces simultaneously, at almost any angle to the camera. The system instantly corrects red-eye and then saves both the original and the corrected image file automatically.
The FinePix S2550HD will be available in March 2010 at a retail price of $249.95.
