Compact Cameras
Fujifilm FinePix F70EXR Digital Camera
Long-Zoom Compact Camera Offers DSLR-like Capabilities in an Affordable, Stylish Package
FUJIFILM U.S.A., Inc. announced the FinePix F70EXR, a sleek, compact digital camera that combines intuitive use with the most advanced features and technology available in a point-and-shoot digital camera. The announcement of the FinePix F70EXR also marks Fujifilm’s first model in the growing long-zoom compact segment with an impressive Fujinon 10x wide angle optical zoom.
Encased in a beautifully sculpted metal shell with a double coated lacquer finish and measuring only 22.7mm thick, the FinePix F70EXR offers several enhancements over its predecessor, the FinePix F60 and boasts marked improvements over competing long-zoom digital cameras, particularly in the areas of design, image quality and capture technology.
“The FinePix F70EXR, which has been designed specifically for taking demanding shots in challenging conditions, requires a sophisticated sensor and control algorithms to ensure every shot looks the very best,” said David Troy, marketing manager, Consumer Digital Cameras, Electronic Imaging Division, FUJIFILM U.S.A., Inc. “By adding our EXR technology to the FinePix F70EXR, users will achieve outstanding images in virtually any lighting condition, and have the advantages of a 10x zoom that fits in your shirt pocket.”
Super CCD EXR
Long zoom compact cameras, as opposed to standard compact digital cameras, typically use a smaller sensor that is vulnerable to difficult lighting conditions since light has a harder time reaching the CCD sensor. To mitigate this vulnerability, Fujifilm has introduced its award-winning EXR technology into the FinePix F70EXR, allowing for significant improvement in image quality against the competition.
Introduced earlier this year with the FinePix F200EXR, Fujifilm’s EXR technology uses the human eye as the basis for the perfect camera sensor, creating a Super CCD sensor capable of registering excellent levels of detail when switched to its HR (High Resolution) mode. The FinePix F70EXR is also capable of offering excellent quality in low light and superb highlight detail in contrast light when switched to its SN (High Sensitivity and Low Noise) mode and DR (Wide Dynamic Range) modes respectively.
EXR Modes
An advanced feature on the FinePix F70EXR, ‘EXR Auto’ helps take the guesswork out of setting the camera by doing it for you. EXR Auto is a sophisticated set of program modes that can automatically detect six different types of scenes – Portrait, Landscape, Macro, Backlit Portrait, Night, and Night Portrait. The camera will recognize the scene and optimize focus, color balance, exposure, flash and sensitivity and will automatically switch the sensor to HR, SN or DR mode depending on the lighting conditions of the scene. By using EXR Auto, users can let the camera do all the hard work and concentrate more on getting the best shot possible.
Multi Frame Technology: Pro Focus Mode / Pro Low-light Mode
New Fujifilm EXR digital cameras, including the FinePix F70EXR will offer several new shooting modes that combine the power of Super CCD EXR with Multi Frame Technology to enable users to capture exceptional images that rival the most expensive professional D-SLR cameras.
Typically, one of the ways to distinguish ‘D-SLR’ photography from ‘compact’ photography has been the use of ‘wide aperture’ to create mood and depth in a picture. These ‘professional’ shots are now possible on the FinePix F70EXR, which uses Pro Focus Mode to combine two or three burst shots together. Through complex digital imaging technology, a crisp shot of the subject is synthesized against a defocused background and foreground. Ideal for portraiture, nature photography or any subject that needs ‘lifting’ from its background, the FinePix F70EXR Pro Focus Mode provides satisfying professional results at the touch of a button.
Meanwhile, Pro Low-light Mode is applied to solving the problems of noisy low light shots. With current cameras, it is possible to achieve relatively blur-free low light shots using high ISO and CCD shift mechanical image stabilization. However, high ISO settings typically come at a cost, as the ISO 1600 setting will invariably produce distracting and ugly noise. In Pro Low-light Mode, the camera will take bursts of four high sensitivity images using Pixel Fusion Technology1 in quick succession. With Multi Frame Technology, the 1st, 2nd, 3rd and 4th images are overlapped to create one image with extremely low noise.
Super Slim 10x Zoom Lens
In conjunction with the Super CCD EXR sensor, the FinePix F70EXR features a Fujinon 10x optical zoom lens that produces crisp high resolution results throughout the focal range, from 27mm wide-angle to 270mm telephoto. The lens of the FinePix F70EXR features Super EBC Coating that keeps ghosting and flare to minimum to allow for optimal picture quality.
Film Simulation Modes
Similar to other high-end FinePix models, the FinePix F70EXR offers five different film ‘modes’ to allow the photographer full creative expression to explore a variety of pre-set color and contrast modes designed around Fujifilm’s most famous film emulsions. The modes are:
  • Velvia/Vivid mode for rich and luscious landscapes
  • PROVIA/Standard mode for excellent, sharp, standard photography
  • ASTIA/Soft mode for soft, fine, smooth tonality
  • Black & White mode captures the dramatic honesty of your image in black and white
  • Sepia mode creates a sense of nostalgia with the warm brown “antique” tones of Sepia
In the Provia, Velvia and Astia modes, the dynamic range can now be set to 800% to improve and highlight details further.
New ‘Super Intelligent’ Flash
The FinePix F70EXR offers a radically improved flash control system which efficiently controls the level of flash for a given exposure to produce beautifully balanced flash illumination across the foreground and background. Gone are the ugly washout shots where the subject is blasted with light and the background dark and unexposed. Super Intelligent Flash is most useful in macro photography where the contrast between subject and background can be especially challenging, but is also effective for night and backlit photography.
New High Contrast LCD
The FinePix F70EXR is fitted with an improved high contrast 230K-pixel 2.7″ LCD. The high contrast LCD is a considerable benefit in bright light, and means that the camera can be pitched at various shooting angles to enable framing of awkward shots. Viewable at 160 degrees both vertically and horizontally, the LCD is bright and clear for beautiful rendition of shots in playback.
Dual Stabilization
Long zoom cameras need stabilization more than any other compact, with handshake and subject movement a particular problem in low light at telephoto range. The FinePix F70EXR reduces blur to a minimum by deploying Picture Stabilization to automatically increase shutter speeds to freeze action, and CCD Image Stabilization to counteract the problems of handshake. By cleverly combining these two, blur is reduced to an absolute minimum.
Face Detection 3.0 and Automatic Red-eye Removal
To provide perfectly exposed and focused portrait shots, the FinePix F70EXR is fitted with Fujifilm’s latest Face Detection technology which is able to track up to 10 faces simultaneously, at almost any angle to the camera. The system instantly corrects red-eye and then saves both the original and the corrected image file automatically.
The FinePix F70EXR will be available August 2009 at a retail price of $279.95.
1 Pixel Fusion Technology: Technology of Fujifilm changing the color filter arrangement. Two side-by-side, same-colored pixels are taken together as a single pixel. The area of imaging elements is doubled, the sensitivity is twice the normal level, and “dark noise” is extremely small. Therefore it is possible to create a high sensitivity image with little noise, instead of increasing the gain from a single pixel and increasing the noise.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
