The Fragmentation Disease: Slowing It All Down
When it comes to computing, there are problems that are more basic than others. Probably at the bottom are hardware problems; all hardware obviously has to be connected and operational for the computer to function. Next would be the operating system, which needs to be in place for any work to be performed on the computer. Once these things are in place, the next thing that must be addressed for optimum performance to occur is the tackling of the fragmentation disease, because file fragmentation–the breaking of files into pieces (fragments) to better utilize hard drive space–is going to affect every computer operation from there on out.
Fragmentation begins to be a problem right from the loading of applications, and continues to drastically worsen as work is performed and files are saved, modified and deleted. All functions are affected. A common example is something one might think wouldn’t be affected by fragmentation: web browsing.
Because web sites are not resident on the computer that’s being used for the browsing, it may seem that fragmentation wouldn’t affect web browsing at all. But the truth of the matter is that any web page accessed–including all graphics, text and design elements, and portions of streaming video and audio–are temporarily downloaded onto the computer being used for browsing. The worse the fragmentation, the more the free space on the hard drive is broken up, which means that all files temporarily saved as part of web browsing are saved in a fragmented fashion. Those files are immediately accessed so that the web page can be viewed, and if they have been saved in a fragmented state, access will take longer. The worse the fragmentation, the longer it will take. If a web page is revisited later, those same files will be retrieved from the hard drive to make access quicker. But again, if the fragmentation disease has run rampant, that access will be considerably slowed down.
The common solution to fragmentation over the years has been scheduled defragmentation–a defragmenter will run periodically, when scheduled, to clean up fragmentation on the drive. The problem with scheduled defragmentation is that in between scheduled runs, fragmentation continues to build and continues to impact performance. And with a function such as web browsing, fragmentation is always occurring as temporary files are saved and overwritten–hence scheduled defragmentation is only making a difference just after it runs. The rest of the time, web browsing runs slower in direct ratio to the fragmentation that is happening.
The best defragmentation solution for web browsing–or any of today’s applications for that matter–is a completely automatic solution, one that defragments invisibly, in the background, whenever otherwise idle system resources are available. Performance is consistently maximized and fragmentation is never a problem again, and operations such as web browsing are always smooth and fast.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
