Fostex PX-5HS Active Bookshelf Speakers
The new Fostex PX-5HS is a 2-way Active Hi-Fi Speaker System consisting of 5.2-inch aramid fiber woofer and 1-inch soft dome tweeter with high performance 35-watt/18-watt digital amplifier. Additionally, a 1-inch Urethane film laminated polyester fiber dome tweeter is tuned with back chamber for smooth high frequency reproduction. There are Rotary Encoders for Volume and Tone Controls with LED indicators. Additionally, Auto Standby / Auto Operation functions for electric power saving are included with a fade in function to gradually increase the output level when powering on.
Fostex PX-5HS BackIt inherits the concept of Fostex reputed professional reference monitor, model PX-5, but has been carefully tuned to hi-fi audio listening with the aim of delivering a natural and clear sound in your listening room. The biggest advantage of an active speaker system is that the speakers and amplifier are best tuned at factory for maximum performance. Space saving is another advantage that is ideal to build a minimal high resolution audio system together with a USB/DAC and a computer.
Price and Availability
The Fostex PX-5HS speakers are available now for $999 a pair.
Specifications
Enclosure type: 2 way bass reflex
Tweeter: 1″ Urethane film laminated polyester fiber dome tweeter tuned with back chamber for smooth high frequency reproduction
Woofer: 5.2″ Crimson woofer of aramid fiber mixed diaphragm impregnated with resin to enhance fiber bonding for higher rigidity
Frequency Response: 50 Hz – 40k Hz
High quality digital amplifier of 35W (LF) and 18W (HF) output power
Unique Rotary Encoder for Volume and Tone Controls with LED indication
Auto Standby / Auto Operation function for electric power saving
Fade In function to gradually increase the output level when powering on
Elegant high grade wood-grain enclosure and beautiful stainless rear panel
S/N Ratio: 86 dB
Distortion (T.H.D.) 0.1%
Crossover Frequency: 2.5 kHz
Subsonic filter: 50 Hz
Dimensions: 280 (H) x 180 (W) x 210 (D) mm
Weight: 5 kgs
Inputs:
XLR-3-31 connector (balanced)
Maximum input level: +24 dBu
Input Impedance: 20k ohm or more
1/4” Phone jack (unbalanced)
Maximum input level: +10 dBV
Input Impedance: 10k ohm or more
RCA jack (unbalanced)
*XLR-3-031 connector and 1/4” phone jack are combined in the combo connector
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
