The Formovie Theater / T1 UST Laser Projector with Bowers and Wilkins Audio System
Offering a good foundation for both video and audio, the Formovie Theater / T1 UST Laser Projector might just the ticket for your home theater set up.
Formovie T1 UST Projector Lifestyle
June 30, 2022 Update: The Formovie T1 has been named Formovie Theater for U.S. markets. It offers an AndroidTV operating system, instead of the proprietary FengOS, and a new color management system (CMS). Otherwise the Formovie Theater and Formovie T1 are the same.
November 3, 2023 Update: The $2,999 Formovie Theater won Best UST 4K Projector for the second year in a row at the 2023 Laser TV Showdown.
July 25, 2024 Update: Formovie Theater’s ANSI brightness specification has been corrected to 1800 lumens (it was previously stated at 2800 lumens).
Formovie Theater
British high-end loudspeaker maker Bowers & Wilkins has partnered with Fengmi to provide an integrated sound system for their Formovie Theater / T1 4K UST Laser Projector. UST stands for Ultra Short Throw, which means that the projector can display a very large image at a very short distance from the screen as illustrated in the photo.
Related article: Samsung The Premiere LSP9T UST Projector Review
Nearly every TV manufacturer is now offering UST projectors, and because they sit front and center of the room, there’s an opportunity to bundle sound bar capabilities into one box.
It seems projector companies without audio know-how are partnering with established audio brands for credibility.
Although, it’s quite intriguing to learn that Bowers & Wilkins has partnered with a relatively unknown China-based brand. However, they’re not the only ones. Previously, we reported on Dynaudio providing audio systems for the JMGO 01 and JMGO U2 UST Laser Projectors — another company based in China.
Bowers & Wilkins Sound
Bowers & Wilkins Speaker Exploded for Formovie T1 UST Projector
Bowers & Wilkins Speaker for the Formovie T1 Projector
The Bowers & Wilkins stereo sound system features two forward-firing 70mm glass-fiber Low/Mid frequency drivers and two 20mm titanium tweeters, all mounted in rigid ABS+GF enclosures, located at the outer edges of the front baffle to ensure good dispersion.
The two bass/mid drivers are ported to each side of the projector and feature Bowers & Wilkins Flowport technology which minimizes turbulence by incorporating dimples on the speaker surface, while the tweeters are protected by the proprietary, high transparency speaker mesh.
Bowers & Wilkins specified a high-quality, 2 x 15W, TI (Texas Instruments) amplifier and Dolby MS12 decoder while also including discrete sound modes specially tuned by their engineering team.
formovie-t1-sound-waves-top
The built-in B&W system is designed to provide impactful sound with crisp dialogue, uncolored midrange, and good bass extension, projected into the room beyond the confines of the speaker enclosure.
Dolby Atmos and DTS HD decoding is also provided. Although no additional audio processing details are provided, it is assumed that the projector employs downmixing and virtual surround processing to provide a Dolby Atmos/DTS HD listening experience from its two-channel configuration. Also, with the projector’s HDMI-eARC port it can pass Dolby Atmos and DTS-HD bitstreams to a compatible external audio system if desired.
Formovie Theater Features
The core video features of the Formovie Theater / T1 UST include:
  • Product name: Fengmi Formovie Laser TV T1 / Formovie Theater
  • Processor: MediaTek MTK MT9669
  • RAM: 3GB DDR4
  • Built-in Storage: 64GB eMMC high-speed flash memory
  • Imaging Chip: TI (Texas Instruments) single DLP chip  (exact size/model not provided)
  • Resolution: 4K UHD via XPR Pixel Shifting.
  • Laser Light Source: ALPD® RGB+  20,000 hour use life.
  • Light Output: 2800 1800 ANSI lumens max white light output
  • Native Contrast Ratio: 3000:1
  • Wide Color Gamut: BT.2020
  • Screen Size: 80 to 150-inches. The T1 can project a 100-inch image from a distance of 20cm (approx 7.9 inches)
  • THX Certified: Formovie laser projectors were the first ultra-short throw models to receive THX certification
  • HDR: Dolby Vision, HDR10, HDR10+ compatibility.
  • Motion Processing: MEMC smooth motion.
  • Control: Voice Remote provided.
  • Connections:
    • HDMI 2.0 (3) – HDMI Input 3 is eARC enabled
    • USB (2)
    • Headphone 3.5mm (1)
    • Digital Optical Audio (1)
    • Ethernet (1)
    • Wi-Fi
  • Fan Noise: Less than 28dB
  • Dimensions: 550 x 349.2 x 107.5mm (21.7 x 13.74 x 4.32 inches)
  • Weight: 9.8kg/21.6 pounds
Formovie T1 UST Projector Rear Connections
Pricing & Availability
The Formovie Theater is available for $2,999 at ProjectorScreen.com.
Tip: The Formovie Theater has won Best UST projector two years in a row at the 2022 Laser TV Showdown and 2023 Laser TV Showdown.
Related reading: Every UST Laser Projector Compared
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
