Preview: Formovie Introduces Affordable Cinema Edge UST 4K Projector with Google TV
At $2,199, the Formovie Cinema Edge UST 4K Projector is the North American version of the Formovie C3.
Formovie Cinema Edge UST 4K Projector Angle
Formovie has introduced an affordable 4K UST Projector called the Cinema Edge for $2,199. It is a replacement of Formovie’s C3 from last year, but now includes a Google TV operating system. That means it supports Netflix, YouTube, Amazon Prime Video, Disney+, Apple TV, HBO, Peacock, etc) as well as the ability to use Google Cast (aka Chromecast built-in). Since the prior model ran Formovie’s proprietary operating system which didn’t support Netflix, the switch to Google TV OS means owners no longer need a separate set-top box or streaming stick to use Netflix.
Formovie Cinema Edge UST 4K Projector Front High
Cinema Edge Features
In addition to Google TV and Netflix certification, the Formovie Cinema Edge employs DLP projection technology with support from a long-lasting Laser light source.
Images up to 150 inches can be projected from less than two feet away due to the Cinema Edge’s ultra-short throw (UST) design.
The color range is wide and accurate with a 110% Rec. 709 color gamut and a 3,000:1 contrast ratio.
With 1900 lumens output (ISO rating) and multiple brightness modes (Office, Viewing, Night) users can optimize the projector’s brightness levels based on different environments.
The 60Hz refresh rate, 2GB RAM, and 32GB of storage provide support for stable streaming and fast, reliable performance.
Formovie Cinema Edge UST 4K Projector Inputs
The Formovie Cinema Edge provides three HDMI 2.1 (eARC) ports, and two USB 2.0 ports for convenient connectivity to external devices.
With (MEMC) Motion Estimation, Motion Compensation the Formovie Cinema Edge reduces blurring on moving objects, providing a smoother and more lifelike visual experience.
In addition to video, Formovie has also given thought to the audio portion of the equation. Dolby Audio and DTS:X are supported. Users benefit from reduced noise levels, with the projector operating at a maximum of 32dB Fan Noise so as not to be distracting of the viewing experience.
The projector is also designed to protect the eyes, providing a comfortable and enjoyable viewing experience. Users can also personalize their space by seamlessly blending the projector into their home setup with custom images or photos as the screensaver. These and more features can be explored with ease through the intuitive “All Settings” menu.
Formovie Theater UST Projector
Tip: The step-up Formovie Theater UST 4K Projector won ProjectorScreen’s UST Showdown two years in a row.
Comparison
Formovie Cinema EdgeFormovie Theater
MSRP$2,199$3,499
$2,799
THX CertifiedYes
ProcessorMediaTek MTK MT9669MediaTek MTK MT9669
RAM2GB3GB
Storage2 x 32GB eMMC high-speed flash memory64GB eMMC high-speed flash memory
Imaging ChipSingle Chip DLPSingle Chip DLP
Resolution4K UHD via XPR Pixel Shifting4K UHD via XPR Pixel Shifting
Laser Light SourceSingle Laser with 20,000-hour use lifeTriple Laser with 20,000-hour use life (ALPD® RGB+)
Light Output1900 (ISO Lumens)1800  (ANSI Lumens)
Native Contrast Ratio (Full On/Full Off)3000:1 3000:1
Color Camut110% Rec 709BT.2020
HDR SupportHDR10Dolby Vision, HDR10, HDR10+
Throw Distance0.23:10.23:1
Screen Size80 to 150 inches80 to 150 inches
Motion ProcessingMEMC smooth motionMEMC smooth motion
Keystone CorrectionHorizontal and Vertical
(8 points)
(8 points)
Dolby Atmos PassthroughYes
Built-in Audio15 watts x 2
(Dolby Audio/DTS-HD/DTS:X support)
15 watts x 2
(Bowers & Wilkins)
Smart OSGoogle TVAndroid
Netflix CertifiedYes
Chromecast Built-in (Google Cast)Yes
Gaming SupportALLM ALLM
HDMI3 x HDMI 2.1 eARC enabled3 x HDMI 2.1eARC enabled
USB 22
Headphone Out1 x 3.5mm
Digital Optical Out11
Ethernet YesYes
Wi-Fi YesYes
BluetoothYesYes
Voice Control Google AssistantGoogle Assistant
Fan Noise32dB28dB
Dimensions (HWD)3.58″ x 17.95″ x 12.12″4.23″ x 21.65″ x 13.74″″
Weight15.43 lbs21.6 lbs
Initial Impressions
We’ve been told the Formovie Cinema Edge is the North American version of the Formovie C3 which we saw at the 2023 UST Projector Showdown. Although it didn’t take any of the top spots, we felt it was a solid performer as an entry-level, relatively low-priced unit. With the addition of Google TV OS and Netflix certification, the Cinema Edge becomes a much more attractive option.
Price & Availability
The Formovie Cinema Edge UST 4K Projector is available for $2,199 at ProjectorScreen.com
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Epson just expanded their high brightness Q Series projector line to include a UST projector for those looking for a discrete large screen viewing...
The Hisense L9Q wins eCoustics Best in Show at CES 2025 in the UST Projector category
Daily Deals
Check out our favorite UST projector deals for Black Friday 2024 on projectors that we would actually buy for ourselves or recommend to friends...
This year's Battle Royale of UST projectors brought eight contenders into a room. Find out which one emerged victorious.
At $2,499, the Hisense PL2 ultra-short throw projector has a lot in common with the previous PL1 but it can project a larger 150-inch...
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
Formovie is not alone, Epson catches a number of projector competitors overstating brightness specifications.
Offering a good foundation for both video and audio, the Formovie Theater / T1 UST Laser Projector might just the ticket for your home...
