Focal XS Book Multimedia PC Speakers
Focal has introduced a high-end desktop stereo speaker system for Mac or PC. The new Focal XS Book comprises two active loudspeakers, which are as simple as they are very high performance.
Focal XS Book is the obvious next step after the first multimedia Focal XS 2.1 system that pushed back the limits in terms of computer sound system with its bass enclosure, its speakers, and its integrated iPod dock. All the multimedia/audio press was unanimous in their comments and praise for this new product, which encouraged Focal to pursue other compact, super high-quality designs for the multimedia field.
Focal XS Book Multimedia Speakers
This time, there is no dock, no sound card, there are only active loudspeakers to join to the computer via an analog cable (RCA inputs or 3.5mm jack).
Focal technologies used in the XS Book include an aluminum dome tweeter and a 4″ (10cm) proprietary Polyglass cone woofer, which permit XS Book to cover a large bandwidth from 55Hz to 22 kHz, with a maximum sound pressure level of 96dB SPL at 1m In fact, this special woofer is actually the same design as in our pro monitors. Other notable designs are the vented port with complex shapes to control air-flow turbulence and noise, and a high- performance, custom-made 2 x 20 Watt amplifier.
So much more than a ‘computer’ or desktop speaker, XS Book will happily leave the desk to go to another room. Thanks to its big, powerful sound, it can accompany a flatscreen TV or be used as music dedicated speakers on a stand or on a bookshelf! There are many possible applications for Focal XS Book where it will shine.
We also designed it to be easy-to-use. It needs only to be connected to the mains, an audio signal supplied by 3.5mm or RCA inputs, and the supplied cable to connect the master speaker to the slave.
Finally, XS Book is compatible with the Omnimount AB2 norm in order to be easily combined with all accessories (on-wall fixing jointed or fixed for example).
Focal XS Book Multimedia Speakers with PC
Simply put, Focal XS Book integrates the multiple successful innovations and technologies from XS 2.1 and the CMS pro monitors in a consumer-friendly format for any application or household.
Very simple to use, but technically very advanced, this loudspeaker doesn’t lose sight of its first priority: sound.
Like all Focal loudspeakers, the XS Book is tuned by computer analysis, and then fine- tuned to perfection by ear. Every drive-unit we manufacture is fine-tuned for the speaker to which it is destined. Such attention to detail results in an unparalleled sound. The design of the XS Book absolutely respects every fact of our design philosophy.
It will produce exquisite quality sound, at any volume, and has a natural sounding deep bass that belies its size.
Focal XS Book Multimedia Speakers with iMac
Specifications
Type 2-way bass-reflex active loudspeaker
Drivers Polyglass 4″ (10cm) midbass 19mm Aluminum tweeter
Frequency response (±3dB) 50Hz – 22kHz
Low frequency point 44Hz
Crossover frequency 3 000Hz
Dimensions (HxWxD) 11 x 4-1/2 x 7-7/8″ (281 x 114 x 200mm
Net weight 11 lbs (5kg)
US MSRP $399
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
Shopping for wireless noise cancelling over-ear headphones or gaming headsets? Here are our picks for best you can buy on any budget.
Focal Naim America debuts “Mixed on Focal #7” and the “Holiday Cheer Mix,” highlighting new tracks mixed or mastered on Focal’s professional studio monitors.
2025 Black Friday tech deals you won't want to miss on premium hi-fi, headphones, and home theater gear this Holiday Season.
Focal’s Mu-so Hekla launches November 6 in Seoul before expanding globally in 2026. Priced at $3,600 USD, it’s a Dolby Atmos powerhouse built on...
Daily Deals
The award-winning Focal Bathys Black Silver wireless headphones are now $699 for the holidays—offering true hi-fi sound, ANC, and luxury design at their best...
