CES 2023: Focal’s Vestia Loudspeaker Lineup Delivers Affordable High-End Performance
Focal’s new Vestia series of high-fidelity loudspeakers sits between its Chora and Aria speaker lines, priced from $1200 to $4400 a pair.
Focal Vestia Speakers 2023
Focal is on hand at CES 2023 with an expansion of its home loudspeaker products with the new Vestia series; the affordable lineup includes five speaker models that are designed to deliver sonic purity and significantly improved treble reproduction.
The launch of the Focal Vestia Series, however, is not the end for the award-winning Focal Chora loudspeakers which remain in the catalog; a move that we think makes a lot of sense because of the high performance and value that they offer.
Focal Vestia Loudspeakers 2023 Lifestyle
The five speakers in the Vestia line are:
  • Vestia N°2, Vestia N°3, and Vestia N°4 floorstanding models.
  • Vestia N°1 bookshelf loudspeaker.
  • Vestia Center channel speaker.
Core Features
In addition to improved sound quality, the Vestia line incorporates a visually pleasing design that blends in with any decor.
Inspired by Vesta and Hestia, the goddesses of the hearth and the home, Focal is offering the following finish options: Black High Gloss, Dark Wood, or Light Wood for the side panels, accompanied by a black or white leather effect for the front panels. Added finish details include metallic rings that surround the drivers. A matching grill is provided with each speaker for those that don’t like to have the cones exposed.
Being specialists in loudspeaker driver construction, Focal has chosen to incorporate its Slatefiber cone for the Vestia loudspeakers.
First used in the Focal Chora in 2019, the Slatefiber is made from recycled carbon fibers. This approach to cone material was well received by the market and Focal’s engineers have continued to update the technology since the initial launch. This has resulted in even higher performance capability, and was adapted for the Alpha Evo studio monitors and made available for in-car kits via the Slatefiber line.
Focal Vestia Tweeter
Focal also incorporates its innovative ‘M’-shaped dome TAM tweeter to optimize treble response. This tweeter was first used by Focal in its car audio collection but has been adapted to work comfortably with hi-fi loudspeakers.
For additional support, Vestia loudspeakers include a front-directed port for impact and a rear port for extended low-frequency bass response.
Vestia Specifications
Focal Vestia Model N°1 N°2N°3N°4Center
DescriptionBookshelfFloorstandingFloorstandingFloorstandingCenter
Speaker Type2-way bass-reflex 3-way bass-reflex 3-way bass-reflex 3-way bass-reflex2-way bass-reflex
Woofer
2 x 6.5″ (16.5cm) Slatefiber Woofers3 x 6.5″ (16.5cm) Slatefiber Woofers2 x 81/4” (21cm) Slatefiber Woofers
Mid-bass/ Midrange6.5″ (16.5cm) Slatefiber Midbass6.5″ (16.5cm) Slatefiber Midbass6.5″ (16.5cm) Slatefiber Midrange6 1/2″ (16.5cm) Slatefiber Midrange2 x 6 1/2″ (16.5cm) Slatefiber Mid-bass
Tweeter 1″ (25mm) Al/Mg inverted dome TAM tweeter1″ (25mm) Al/Mg inverted dome TAM tweeter1″ (25mm) Al/Mg inverted dome TAM tweeter1″ (25mm) Al/Mg ‘M’-shaped inverted dome TAM tweeter1″ (25mm) Al/Mg inverted dome TAM tweeter
Sensitivity (2.83V/1m)89.5dB91.5dB92dB92dB91.5dB
Frequency response (+/-3dB) 56Hz – 30kHz47Hz – 30kHz42Hz – 30kHz58Hz – 30kHz58Hz – 30kHz
Low-frequency point (-6dB) 48Hz37Hz35Hz34Hz50Hz
Nominal impedance 8 ohms8 ohms8 ohms8 ohms8 ohms
Minimum impedance 4.5 ohms3 ohms2.9 ohms2.6 ohms3.6 ohms
Recommended amplifier power 25 – 120W40 – 250W40 – 300W40 – 350W40 – 200W
Crossover frequency 2,800Hz280Hz/2,800Hz280Hz/3,100Hz280Hz/2,800Hz2,700Hz
Dimensions (WxDxH) 8.6″x10.25″ x 15.25″ 10.2″ x14.6
x 39.8″
10.2″ x 14.75″ x 44.25″ 12″ x 16.8″ x 44.6″ 21.2″ x 10.25″ x 8.5″
Net weight (with grille) 15.4lbs (7kg)57.3lbs (26kg58.4lbs (26.5 kg69.45lbs (31.5kg)22lbs (10kg)
Price (each) US$599$1,399$1,799$2,199$699
Price (each) CAD$769$1,799$2,299$2,799$899
Focal Chora Sub 600p
These speakers can be combined with the SUB 600P subwoofer ($1,199 US) for deep and encompassing bass.
In addition, tilted stands are offered that help the speakers provide an optimal and natural soundstage, that is focused on the listener.
  • Stands (pack of two): $249 US, $319 CAD
  • Center Stand:  $129 each US, $169 each CAD
Focal Vestia Speakers Stands
Price & Availability
Vestia pricing is listed below with availability January 2023 at Focal Powered by Naim Store Locations and other Authorized Dealers.
  • Vestia N°1 – the superbly compact bookshelf model
    • $599 each / $769 each CAD
  • Vestia N°2 – the leading 3-way floorstanding model for uncompromising sound quality
  • Vestia N°3 – the 3-way floorstanding model for balanced and vibrant listening experiences
  • Vestia N°4 – the 3-way floorstanding model with two 81/4” (21cm) woofers, for deep bass with impact
  • Vestia Center – the 2-way central model, which enhances the dialogue in your films
    • $699 each / $899 each CAD
  • Stands$249 (pack of 2) / $319 (pack of 2)
  • Center Stand$129 each / $169 each CAD
For more details go to the Official Focal Vestia Webpage.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
