In-Wall Speakers
Focal’s UTOPIA CINEMA LCR Speaker and Subwoofer Will Be a Popular Choice for Premium Home Theaters: ISE 2025
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Focal Utopia Cinema LCR Speaker Front Angle
Focal has a formidable track record in the loudspeaker category and is on hand at ISE (Integrated Systems Europe) from February 4th through 7th 2025 with several products including its previously released Utopia Diva wireless speakers, and is also debuting a new product offering, the UTOPIA CINEMA product line.
The line includes two products: the CINEMA LCR speaker and the CINEMA SUB. However, the speaker and subwoofer can be used to assemble a complete multi-speaker home theater setup.
Tip: LCR stands for Left, Center, Right – this means that the CINEMA LCR speaker can be used as a left, center, or right channel speaker – but it can also be used as a surround speaker if desired. Also, note that the subwoofer is a passive sub and not a powered sub – this means it requires external amplification.
The UTOPIA CINEMA line is designed for custom-installed private cinema setups in rooms up to 2153 sq ft (200m²)
Focal Utopia Cinema Series Front
A result of extensive development, these CINEMA LCR and CINEMA Sub are designed to deliver high-end performance for a complete modular solution for custom systems. With UTOPIA CINEMA, FOCAL is set to revolutionize the ultra-high-end integration market.
The UTOPTIA CINEMA line features the latest Focal audio technologies from its professional division, including the revolutionary Utopia Main studio monitors unveiled on January 15, 2025. With their high level of immersion, resolution, and low-frequency impact, the UTOPIA CINEMA loudspeakers are designed to significantly improve the movie watching experience at home.
CINEMA LCR
The CINEMA LCR is a full-range (3-way), high SPL-capacity loudspeaker that can support power and precision, adapting to the requirements of the most optimized listening environments. Flexible crossover settings, such as the 0–30° selector, support the optimized performance of each loudspeaker depending on its purpose (central, left, or right channel), while its speaker drivers are designed to offer excellent clarity, detail, and the dynamic punch required for high-end home theater installations.
Focal Cinema Switches
Tweeter: The CINEMA LCR’s tweeter incorporates beryllium and its ‘M’ shape helps to deliver superior transient response and accurate treble sound reproduction, with unparalleled precision. The tweeter’s power handling is improved by a 1″ coil and optimized heat dissipation. This speaker driver extends the ultra-high response with no distortion while halving THD to 3kHz thanks to TMD® (Tuned Mass Damper) technology complete with a Poron surround. Lastly, its rear acoustic environment is fully optimized with a waveguide and IAL (Infinite Acoustic Load) technology, further enhancing its sound performance.
Midrange: New 5″ ‘M’-shaped, ‘W’-cone midrange The midrange is capable of delivering an impressive dynamic range and transparency, thanks to the sound optimization of its magnet to prevent resonance. Moving in a perfect piston movement, the ‘M’ shape creates a completely flat wave thanks to its shallow depth. In addition, its small-roll surround with integrated TMD technology significantly reduces the intermodulation created by the surround. The goal of the driver is to provide timbral accuracy and a very high level of resolution.
Woofer: The CINEMA LCR employs a 13″ high-excursion ‘W’-cone woofer This speaker driver is housed in a solid cabinet, fitted with a large vent for enhanced bass response. By combining super-light moving components with a flexible surround, it offers excellent articulation and definition.
CINEMA SUB
FOCAL UTOPIA CINEMA SUB
Focal claims that the UTOPIA CINEMA SUB is the ultimate subwoofer for demanding rooms. Its two 13” woofer drivers support maximum excursion and precise bass control. Tuned to 19Hz, the CINEMA SUB is designed to support deep and impactful bass. With advanced sound design, it blends easily into multi-channel systems, enhancing sound effects or deep musical tones for a fully immersive experience.
Focal also includes a large front-mounted rectangular slot (laminar) port for added support for the two 13-inch woofer drivers. The port is designed to minimize distortion while maximizing sound pressure, descending to lower frequencies while increasing their efficiency, for more impactful sub-bass. Its heavy-duty construction is designed to deliver the highest SPL (Sound Pressure Level) when needed (without blowing out your ears).
Pro Tip: Focal states that CINEMA SUB can be integrated into wave-forming and other bass-management configurations.
Specifications
Focal Diva Utopia Cinema and Sub
ModelFOCAL CINEMA SUBFOCAL CINEMA LCR
Speaker TypeSubwoofer
(In-wall / On-wall / Freestanding)
Loudspeaker
Driver ConfigurationNot Applicable3-way
Driver Complement 2×13” ‘W’ cone woofers13” ’W’ cone woofer
5” ‘M’-shaped midrange with ‘W’ cone
1.5” ‘M’-shaped beryllium tweeter
Tuned Port (Bass Reflex)9Hz 35Hz
Sensitivity (2.83V/3feet – 1m)95dB (66Hz)93dB (250Hz)
Frequency Response (-3dB) 2Pi42Hz – 2500Hz35Hz-20kHz
Low-frequency cut-off (-6dB)20Hz – 2500Hz30Hz-20kHz
Recommended EQ19Hz – 2500Hz ±1dB
+12dB @20Hz Q=1.8 and shelving -5dB @50Hz (1st order) and 24 dB/oct @18Hz
Not Applicable
Nominal impedance
Minimal impedance4.1Ω to 19Hz3.5Ω to 150Hz
CrossoverNot Applicable360Hz / 2600Hz
Midbass level adjustmentNot Applicable-2.5dB / 0dB / ±2.5dB (100Hz – 400Hz)
Midrange level adjustmentNot Applicable-1.5dB / 0dB / ±3dB (400Hz – 2.5kHz)
Tweeter level adjustmentNot Applicable-2dB / 0dB / ±2dB (2.5kHz – 10kHz)
Listening position adjustmentNot Applicable0° / 30°
Rated power Handling300W RMS (4Ω)150W RMS (8Ω
Recommended amp powerMax 400W (8Ω) / Max 800W (4Ω)Max 400W (8Ω) / Max 800W (4Ω
Dimensions (HWD)45.7/8′ x 21.5/8 ‘x1 2.13/16 inches
116.5 x 54.9 x 32.6 cm
45.7/8 ‘x 13.7/8′ x 12.13/16’ inches
116.5 x 35.2 x 32.6cm
Net weight161 lbs (73 kg)114.64 lbs (52kg)
FOCAL UTOPIA CINEMA Home Theater Setup
The Modular Approach
One of the great things about Focal’s Utopia Cinema loudspeakers and subwoofers is that they can be installed as a modular system. They can be fixed onto or into the wall, or positioned horizontally or vertically until the desired number is installed and placed where needed.
The setup configuration is limited only by the size of the room. The Cinema LCR and Cinema SUB can also be combined with loudspeakers from the Focal 1000 In-wall/ceiling Series. Both ranges feature the same technologies, from the ‘W’ cone to the beryllium tweeter, and both deliver an immersive listening experience with the same signature sound.
The Bottom Line
With versatile setup options, Focal’s new UTOPIA CINEMA series offers a step-up solution over in-wall speakers for custom home theater installations with fewer space concerns.
For those attending ISE, Focal will also be showing the recently released Diva Utopia wireless speakers, the ST6 loudspeaker line with a new black finish, and their Sopra Speakers matched with the NAIM 200 Classic Series amp and streaming products.
Pricing & Availability
Both products are expected to be available starting in September 2025.
Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
HDTV 4K & 8K TV
HDTV 4K & 8K TV
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
Hi-Fi Components
Experience the latest from Naim and Focal at AXPONA 2025, including the North American debut of the Bathys MG wireless headphones.
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
