Car Speakers
Focal’s P60 Limited Edition Speaker Kit Will Turbo Charge Your Porsche 911 Experience
Focal’s P60 Limited Edition Loudspeaker Kit is designed to turbo charge the audio performance of your 911 and other Porsche models.
Focal P60 Limited Edition Car Audio Speaker Kit for Porsche 911 in Suitcase
Focal charged into 2023 with both engines running; the French manufacturer updated its affordable loudspeaker lineup with the new Vestia and Theva ranges and also introduced the new Littora architectural outdoor/marine speaker line-ups.
Focal has become one of the leading manufacturers of high-end headphones including the award-winning Bathys and Utopia 2022, and also has a rather large presence overseas in the car audio market which makes their new P60 Limited Edition Car Kit of special interest.
Crafted in Focal’s workshops in France, the P60 Limited Edition is a high-fidelity, in-car, plug & play kit, compatible with Porsche 911 (992) vehicles. Additional models include the Porsche Panamera (971 / 2017 – 2023), Porsche Cayenne (PO536 / 2018 – 2023), and Porsche Taycan (2020 – 2023).
The kit comes in a suitcase that is packed with two 8-inch woofers (P60WF), three 4-inch midrange speakers (P60MED) fitted with a ‘W’-shaped cone, and a pair of 1-inch inverted dome beryllium tweeters (P60TW).
Focal P60 Limited Edition Car Audio Speakers for Porsche 911 and other models
Focal’s exclusive speaker technologies support detail, uncolored sound, powerful and dynamic bass as well as an even larger soundstage.
The speakers are easy to install in the vehicle’s original spaces. If you want to do it yourself, a quick start installation guide is included. However, if you want them installed professionally contact your local Focal or Porsche dealer.
Tip: The reason the speakers come in a suitcase is that it is adapted to fit easily in the trunk of a Porsche 911. This gives a second life to the packaging as it can become a suitcase for the buyer once you remove the speakers and documentation.
Focal P60 Limited Edition Car Audio Speakers for Porsche cars
Speaker  ModelP60TWP60MEDP60WF
Speaker TypeTweeterMidrangeWoofer
Quantity232
Power Handling (max)100W100W200W
Power Handling (nominal)15W (rms)50W (rms)100W (rms)
Sensitivity (2.83v/1m)93.5dB87dB91dB
Frequency Response2.5kHz to 40kHz150Hz to 2,500Hz35H to 500Hz
Impedance3.3 ohms3.3 ohms3.3 ohm
Driver Size1 ⅝-inches (42 mm)4-inches (100 mm)8-inches (200 mm)
Driver Depth1 inch (24.15 mm)1 ⅜ inches (33.8 mm)2 inches (55 mm)
Cone TypeInverted Dome BerylliumFocal “W”Focal “W”
Voice Coil Diameter¾-inches (20 mm)1-inch (25mm)1 ⅝ inches (40 mm)
Magnet TypeNeodymiumNeodymiumNeodymium
SuspensionFoamButyl RubberButyl Rubber
Weight.11 lbs (50 grams).55 lbs (250 grams)2.65 lbs (1200 grams)
Availability and Pricing
The Focal P60 Limited Edition Porsche Speaker Kit is priced at $6,499.99 USD and is available from Authorized Focal Dealers and Focal Powered by Naim Store Locations while supply lasts.
Important Tip: Only 911 kits are being made available for Focal customers/Porsche 911 owners. Each kit is individually numbered.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Our favorite products for audiophiles and studio professionals from NAMM 2025, including headphones, speakers, and some surprises.
