Focal Launches Listen Wireless Headphones
Focal Listen Wireless Headphones on woman
Focal just announced a Bluetooth version of their Listen wired headphones called Listen Wireless. The identical looking $300 over-ear headphones offer 20 hours of listening time, and have a charging time of less than three hours. The automatic standby feature gives it a total range of 240 hours. It has a reception range of up to 60 feet (15 meters), giving you complete freedom of movement around the source.
Listen Wireless is equipped with a dual omnidirectional microphone system running Clear Voice Capture software for improved voice clarity while talking, even in noisy environments. It also uses the NFC technology available on some smartphones equipped with an NFC module for an easy and quick connection. The controls are located on the ear-pieces, making them even more ergonomic. They have been strategically positioned to enable users to control the functions effortlessly, quickly and easily. The three buttons are grouped into three areas: the on/off and Bluetooth buttons in one area; music and call controls in another; and volume controls. The controls are simple and intuitive, controlled by short or long presses.
Listen Wireless implements Bluetooth 4.1 and aptX compatibility. The ultra-flexible headband makes them light, reduces pressure on the head and increases durability. The memory foam ear cushions made from fabric and leatherette provide excellent isolation, a key feature of Listen Wireless. Focal kept the design of the folding ear-pieces, which makes them easy to use and carry aroundisten Wireless has a scratch-resistant lacquered Black High Gloss finish. Original Listen on the other hand, has a hand-brushed finish. Designed for all sorts of set-ups, these wireless headphones can also be used with a traditional audio cable. When connected to a DAC, they will deliver all the power and scale worthy of a high-end hi-fi product.
Voice notifications and different LED colors indicate the status of the headphones, the battery level, pairing, etc. Up to eight different devices can be stored in the memory of Listen Wireless and two devices can be connected simultaneously. This means users can listen to music from a tablet and answer a call from a smartphone at the same time. Listen Wireless is supplied with a USB cable and an audio cable for wired use, or for when Bluetooth connectivity isn’t possible. A soft carry case allows users to transport the headphones around in complete safety.
Price and Availability
Listen Wireless will be available mid to late July 2017 in Black high gloss finish for $299 USD / $399 CAD. The Listen (wired) that debuted last year is $50 less.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Our favorite products for audiophiles and studio professionals from NAMM 2025, including headphones, speakers, and some surprises.
