Focal’s Bathys MG Might Shatter the Wireless ANC Headphone Performance Ceiling
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
Focal Bathys MG Wireless Headphone in-hand
The high-end wireless headphone category needed a bit of a shake-up in 2025 and it’s not a surprise that Focal has ended Q1 with the launch of the flagship Bathys MG. The French manufacturer of high-end loudspeakers for the home, marine, automotive, and CI categories delivered a rather powerful roundhouse kick back in 2022 with the introduction of the Bathys ANC wireless headphones. The Bathys earned dozens of “Best Wireless Headphone” awards that year from almost every major tech publication and its recognition was well deserved.
The advancement in performance put everyone on notice; Bowers & Wilkins, Mark Levinson, T+A, Noble, and DALI were forced to introduce high-end models into the market and all of them did offer something different than their French counterpart. Competition is always a good thing when it forces others to innovate and often something better for less. Or more in the case of the T+A Solitaire T and DALI IO-12.
Sonos and Dyson also jumped into the deep end of the pool but the market reception was rather lukewarm.
The Bathys earned another award from us in 2024 for the simple reason that nothing new really challenged its position in the category. Focal held firm and introduced the Dune and Deep Black colorways and did update the headphones with firmware updates, but the hardware has remained the same.
The Focal Bathys MG enter the ring at $1,299 USD ($1,699 CDN), which represents a rather substantial increase over the standard Bathys, which currently retail for $699 USD. An additional $600 is a lot of money for consumers who are looking at high-end wireless headphones, and the new iteration will have to be category-leading to make the expenditure a smart upgrade.
The Bathys MG
Focal Bathys MG Wireless Headphones Angle
To take things up a notch, Focal has now added a new model in 2025, the Bathys MG. The MG moniker is shared with Focal’s Clear MG wired headphones. The Bathys MG also incorporates the same M-shaped magnesium dome diaphragm originally introduced in the Clear MG as well as the same chestnut/dark copper colorway. The M-shaped dome of the MG version brought significant sound improvements to the original Clear, so we expect a similar leap in performance with the new Bathys MG.
On the inside, the Bathys MG incorporates Bluetooth 5.2 and improved ANC while on the outside construction is aluminum, magnesium, and leather for a more luxurious look while still providing durability. The headband has been re-engineered (and features real leather) for a lighter feel, and new memory foam cushions provide greater comfort despite the fact that the weight remains roughly the same as the original.
Focal Bathys MG Wireless Headphones Side Close-up
The Bathys MG also sports a new backlit flame logo, magnesium yoke, and aluminum bracket.
There are also new digital microphones to optimize ANC ensuring effective control over ambient noise and improved soundproofing of voices.
The Bathys MG provides up to 30 hours of listening time in wireless mode, 35 hours in jack mode, and 42 hours in USB-DAC mode. It does support quick charging as well so a 15 minute charge nets 5 hours of additional listening.
The USB-DAC mode provides 24-bit/192kHz decoding and supports most common file formats and streaming services.In addition to the EQ which offers both presets and customizable options, the app also provides a hearing test and can customize the listening experience for the user.
The Bathys MG also has a chestnut finish, following the design of Clear MG.
The Bathys MG is shipped in bamboo pulp packaging. Made from plant fibers such as bamboo and sugar cane bagasse, this 100% natural, FSC-certified material complies with the most stringent environmental standards.
Comparison
Focal Bathys MG Wireless Headphones vs. Original Bathys
Bathys MG (2025)Bathys (2022)
Price $1,299$699
Product Type Closed-back wireless headphones with active noise-cancellingClosed-back wireless headphones with active noise-cancelling
Bluetooth TechnologyVersion 5.2 with MultipointVersion 5.1 with Multipoint
Bluetooth Range>15m>15m
Bluetooth Frequency Band2402mHz – 2480mHz2402mHz – 2480mHz
Audio CodecsSBC, AAC, aptX Adaptive, aptXSBC, AAC, aptX Adaptive, aptX
USB-DAC ModeUp to 24-bit/192kHzUp to 24-bit/192kHz
Battery Life30h Bluetooth® Noise Cancelling
35h Jack mode
42h USB-DAC mode
35h Jack mode
42h USB-DAC mode
Fast Charging15 minutes = 5 hours of listening time15 minutes = 5 hours of listening time
Google Fast PairYesYes
Speaker Drivers1-5/8″ (40mm) Magnesium speaker drivers with ‘M’-shaped domes, made in France1-5/8″ (40mm) Aluminium-Magnesium ‘M’-shaped dome, made in France
Frequency Response10Hz to 22kHz15Hz to 22kHz
Harmonic Distortion Rate (THD)<0.2% @1kHz<0.2% @1kHz
Microphones88
Weight0.77 lbs (350g)0.77 lbs (350g)
Carrying case (supplied)9-½ x 8-1/4 x 2 ¾-inches (24 x 21 x 7cm)9-7/16 x 8-1/4 x 2-¾-inches (24 x 21 x 7cm)
Control ApplicationFocal & Naim App, iOS and Android compatibleFocal & Naim App, iOS and Android compatible
Voice Assistant Not indicatedAmazon Alexa, Google Assistant
ConnectionsBluetooth / 3.5mm Jack / USB-C connectorBluetooth / 3.5mm Jack / USB-C connector
Included AccessoriesRigid carrying case
2 cables: 1.2m (3.9ft) Jack cabled., 1.2m (3.9ft) USB-C cable
Quick start guide
Rigid carrying case
3 cables: 1 x 4ft (1.2m) Jack 1/8″ (3.5mm) cable; 1 x 4ft (1.2m) USB-C® cable
The Bottom Line
The Bathys MG doesn’t replace the original Bathys (the Deep Black color option for those headphones was just introduced a short time ago), but instead slots into the line-up above it both in performance and price. The Bathys will continue to occupy the territory in the middle tier where it competes against the models mentioned earlier while the new Bathys MG expands into higher-end territory.
Retailing for $1299, the Bathys MG will need to prove itself, but with Focal’s history and capability, we suspect that it will live up to the challenge. Stay tuned for our forthcoming review.
Man wearing Focal Bathys MG Wireless Headphones
Price & Availability
The Focal Bathys MG Wireless Headphones are available now for pre-order at $1,299 at Crutchfield ($1,699 CAD) and will start shipping May 2025.
The current Bathys is available for $699 at Amazon.
For more information: focal.com
Note: This article was written in collaboration with W. Jennings.
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
