Focal’s Aria Evo X Series Has Us Green With Envy
One of Focal’s most successful loudspeaker ranges is getting a massive refresh for 2024. The Aria Evo X Series are making a huge splash at CES 2024.
2024 Focal Aria Evo X Loudspeaker Family
Focal had a very successful 2023 highlighted by the introductions of the Vestia and Theva loudspeaker lineups. The Focal Powered by Naim retail experience also expanded with new locations in 4 North American markets.
Additional products announced in 2023 included the P60 Limited Edition speaker kit for the Porsche 911 and the French manufacturer made a big splash at the 2023 CEDIA Expo with an impressive showing of the Grand Utopia EM EVO/Naim Statement Amp system.
Aria Evo X Speakers
To start 2024, Focal is pulling back the curtains on its new Aria Evo X loudspeaker series.
Since the initial launch of the Focal Aria 900 loudspeakers in 2013, the Aria range has been popular with many audio enthusiasts. With each reincarnation, Focal’s flagship technologies, such as the TNF tweeter or Flax cone, have been integrated into the new loudspeakers.
The Focal Aria Evo X feature a number of significant changes and new finish options.
Focal Aria Evo X Speakers Home Theater Lifestyle
Five Speakers
The five speakers in the Aria Evo X line are:
  1. Aria Evo X N°1 (bookshelf speaker) – $2,398 pair
  2. Aria Evo X N°2 (floorstanding speaker) – $4,798 pair
  3. Aria Evo X N°3 (floorstanding speaker) – $5,198 pair
  4. Aria Evo X N°4 (floorstanding speaker) – $5,998 pair
  5. Aria Evo X Center (center channel) – $999 each
Tip: Evo stands for “Evolution” and offers a step-up in performance and refinement over Focal’s Vestia series.
Core Features
Focal Aria Evo X TAM Tweeter
TAM Tweeter: The Auria Evo X speakers incorporate the latest generation of Focal’s aluminum/magnesium ‘M’-shaped inverted dome tweeter. This tweeter is designed to provide more accurate treble reproduction by extending the range of the high and low ends of the high-frequency range. Its rear sound chamber also limits interference caused by back waves, further increasing its precision.
Focal Aria Evo X TMD Midrange
TMD Midrange: The midrange speaker drivers now incorporate Tuned Mass Damper (TMD) technology. This technology incorporates circular ‘beads’ molded into the surround structure of the driver properly, sized and positioned. They stabilize how the surround behaves to avoid deformation of the cone and any negative impact on the dynamics. The woofer magnet has also been revamped to deliver more low-frequency impact. The crossovers have been redesigned to improve loudspeaker balance and longevity.
Flax Cone: Focal first used Flax Cone technology in the original Aria 900 line in 2013. The cone is made from French flax fiber which produces a very natural sound, free of coloration while boasting a rich midrange and clear bass. As a result, the Flax Cone offers an immersive and dynamic listening experience, reproducing vocals with clarity and definition.
Tip: Focal Speaker drivers are designed and manufactured in France.
Cabinet Construction: Ultra-rigid MDF (medium-density fiberboard) with non-parallel side panels. This limits unwanted vibration, supporting more neutral sound reproduction.
Finishes: The Aria Evo X speaker line is offered in three color options, Black High Gloss, Prime Walnut, and Moss Green High Gloss.
Tip: Aria Evo X speakers also include a leather effect front panel.
2024 Focal Aria Evo X Floorstanding Loudspeakers
Specifications
Aria Evo X ModelN°1N°2N°3N°4Center
MSRP$2,398 (pair)$4,798 (pair)$5,198 (pair)$5,998 (pair)$999 (each)
DescriptionBookshelf/StandmountFloorstandingFloorstandingFloorstandingCenter
Speaker Type2-way Bass Reflex3-way Bass Reflex3-way Bass Reflex3-way Bass Reflex2-way Bass Reflex
Woofer2 x 6.5″ (16.5cm) Flax bass3 x 6.5″ (16.5cm) Flax bass2 x 8″ (21cm) Flax bass
Mid-Bass/Midrange1 x 6.5″ (16.5cm) Flax with TMD® surround1 x 6.5″ (16.5cm) Flax with TMD® surround 1 x 6.5″ (16.5cm) Flax with TMD® surround 1 x 6.5″ (16.5cm) Flax with TMD® surround 2 x 6.5″ (16.5cm) Flax with TMD® surround
Tweeter1 inch (25mm) Aluminium/Magnesium ‘M’-shaped inverted dome TAM 1 inch (25mm) Aluminium/Magnesium ‘M’-shaped inverted dome TAM 1 inch (25mm) Aluminium/Magnesium ‘M’-shaped inverted dome TAM 1 inch (25mm) Aluminium/Magnesium ‘M’-shaped inverted dome TAM  1 inch (25mm) Aluminium/Magnesium ‘M’-shaped inverted dome TAM
Sensitivity (2.83v/1 m)89.5dB91.5dB92dB92.5dB91dB
Frequency Response (+/- 3dB)55Hz – 30kHz45Hz – 30kHz39Hz – 30kHz37Hz – 30kHz57Hz – 30kHz
Nominal Impedance
Minimum Impedance4.6Ω2.9Ω2.8Ω2.5Ω4.3Ω
Recommended Amp Power25 – 120W40 – 250W40 – 300W40 – 350W20 – 120W
Crossover Frequency2,800Hz290Hz/2,400Hz260Hz/3,100Hz280Hz/2,600Hz2,800Hz
Dimensions (HWD)15-3/8  x 8-⅞ x 11 inches (39 x 22.5 x 28 cm)40-¾ x 11-5/8 x 14-⅝ inches (103.5 x 29.4 x 37.1 cm)45-¼ x 11-5/8 x 14-⅝ inches (115 x 29.4 x 37.1 cm)45-¼ x 14-⅝ x 16-½ inches (115 x 37.1 x 42 cm)7-7/8 x 21 x 9-5/8 inches (20 x 53.3 x 24.5cm)
Weight 18.74lbs (8.5kg)55.12lbs (25kg)63.93lbs (29kg)77.16lbs (35kg)23.15lbs (10.5kg)
Focal Aria Evo X N°3 and Center Speaker Lifestyle
Pricing and Availability
After being shown at the 2024 CES, the Aria Evo X speaker line is expected to become available in February 2024 through Focal/Naim Stores and Authorized Dealers including World Wide Stereo. All models can be ordered in Moss Green High Gloss, Prime Walnut, or Black High Gloss.
  • Aria Evo X N°1 – $2,398 pair
  • Aria Evo X N°2 – $4,798 pair
  • Aria Evo X N°3 – $5,198 pair
  • Aria Evo X N°4 – $5,998 pair
  • Aria Evo X Center – $999 each
When they start shipping, check
For more information, visit the Official Focal Aria Evo X product page.
Continue reading more stories from CES 2024.
2 Comments
2 Comments
  1. ORT
    January 11, 2024 at 1:11 am
    Whichever model those green tower speakers are? They are stunning. My favorite colors are green and red but that particular shade of green is gorgeous. Pure class.
    I want them. I also (still) want a Marantz CD60 in Gold/Silver. I am a shallow individual…Honest but shallow.
    HUZZAH!
    ORT
    • Brian Mitchell
      January 11, 2024 at 8:18 am
      Any Aria Evo X model can be ordered in Moss Green High Gloss, Prime Walnut, or Black High Gloss.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
Our top floorstanding loudspeakers for 2025 come from Magnepan, Q Acoustics, KLH, Audiovector, and ATC—five brands delivering standout engineering, scale, and true high-end performance.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
Our favorite wireless speakers of 2025 include models from Audioengine, Denon, Devialet, Edifier, Q Acoustics and Ruark.
