In-Wall Speakers
Focal Unveils 300 ICA6 Angled In-Ceiling Loudspeaker: ISE Barcelona 2022
The Focal 300 ICA6 Angled In-Ceiling Loudspeakers solve a problem and are surprisingly affordable considering the pedigree and advanced driver technology.
Focal 300 ICA6 Angled In-ceiling Loudspeakers
While not a new design that hasn’t been done before by other brands, the new Focal 300 ICA6 Angled In-Ceiling Loudspeaker completes the loop for the French manufacturer.
Most in-ceiling loudspeakers are aimed directly at the floor; that reality might be fine for situations where you are aiming for maximum coverage in a room and not as concerned with recreating the soundstage and hearing rather precise imaging — but that’s not the best way to do it.
If you’ve never listened to a discrete 5.1.2 or 7.1.2 surround setup with each driver pointed directly at your listening position — you’re had a very different and subpar experience.
You would be quite surprised how much music benefits from this type of design when using in-ceiling loudspeakers.
Focal powered by Naim Houston Entrance
Focal is pushing hard in the home theater space; something we noticed during our visit to the the Focal Powered by Naim store in Houston and we suspected based on the design of the two home theater rooms that in-wall and in-ceiling were just around the corner.
The leading French brand has unveiled the 300 ICA6 angled in-ceiling loudspeaker at the ISE exhibition in Barcelona. Discrete and easy to install, this versatile loudspeaker joins Focal’s current 300 Series line. By supplementing its range with a product for hi-fi or Home Cinema setups, Focal can offer a completely reinvigorated listening experience at home and confirms its position as a benchmark in the integrated solutions market.
Focal 300 ICA6 Angled In-ceiling speaker with grille
Focal Technologies
Inspired by the 1000 ICA6 loudspeaker from the high-end 1000 Series range, the 300 ICA6 joins the 300 Series incorporating all the features that made it so successful: meticulous French manufacturing in Focal’s workshops in Saint-Étienne with an Aluminum/Magnesium inverted dome tweeter and Flax cone, exclusive technologies for high quality precision and total sonic coherence with the brand’s classic loudspeaker lines Aria and Kanta.
In addition, the ready-to-paint magnetic grilles supplied with the product ensure a completely unobtrusive installation.
Focal 300 ICA6
The 300 ICA6 has a 61/2″ (16.5cm) speaker driver and is angled at 35° to counteract the “shower effect” experienced with other loudspeakers. The angle also means that it can be positioned in several ways in the ceiling, including in corners for fully discreet sound delivery.
Using the product in a Dolby Atmos®/ DTS:X loudspeaker greatly enhances 3D audio effects and the overall experience, making it the perfect complement for a 300 Series Home Cinema installation. The Easy Quick Install patented technology guarantees quick and tool-free installation, too.
Focal 300 ICA6 Socle
Flexibility
When it comes to designing, developing and manufacturing its products, Focal considers all the ways in which they will be used and tries to design a product pathway of discovery for its clients.
Every Focal system can be added to and/or switched with the next range up within the universe of aesthetically and acoustically harmonious products it has created. As the 300 ICA6 has a similar design and is the exact same size as the 1000 Series products, you can easily grow and develop your system.
Focal 300 ICA6 Angled In-ceiling speaker rear
Pricing & Availability
Focal’s 300 ICA6 angled in-ceiling loudspeaker will be available September 2022 for $499.
For more information, visit: https://www.focal.com/en/custom-integration/in-wall-in-ceiling-loudspeakers/300-series/in-ceiling-speakers/300-ica6
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
In-Wall Speakers
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Hi-Fi Components
On Thursday, February 20, 2025, the latest Focal Powered by Naim luxury audio store opens in Tampa, Florida.
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
