Fluance Announces First Turntables, RT80 and RT81
Fluance RT80 Turntable
Flaunce is launching its first line of Hi-Fi turntables through a Kickstarter campaign. The affordably priced, new RT80 and RT81 belt driven turntables are engineered with premium components for vinyl enthusiasts on a budget. Early Kickstarter backers can get a $50 discount.
The RT80 incorporates an AT91 Audio Technica needle that produces rich sounds. Users will rest in the grooves of their favorite vinyl records at a mere 2.0 grams of tracking force. The slightly more advanced RT81 features an AT95E Audio Technica needle. Both included styluses are renowned for their freedom from noise and distortion, clarity on musical peaks and channel balance.
Fluance Kickstarter Video
The balanced aluminum S-Type tonearm ensures the needle is rested deep in the record’s groove, producing every audio detail indistinguishable from the original record and creating pristine playback. The fluid movement of the bearings within the tonearm, coupled with its advanced anti-skating system, caresses each record to conserve and protect a user’s beloved vinyl collection.
The RT80 and RT81 are crafted with Fluance’s proprietary audiophile-grade MDF wood cabinet, which incorporates isolation feet and a die-cast aluminum platter. This results in a significant reduction in reverberation, leaving listeners with pure stereophonic sound. The RT80 boasts a lightweight, hollow cabinet design, while the RT81 is built with a fully solid body cabinet to further eliminate vibrations.
Fluance RT80 Turntable - back
RT80
Fluance RT81 Turntable - back
RT81
Additional premium components include high-quality Texas Instruments preamp and gold plated RCA line outputs for captivating signal clarity, and a ground terminal that ensures warm, true sound.
Price and Availability
The Fluance RT80 ($199) and RT81 ($249) turntables are available as of May 2016.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
The new turntable includes the Audio Technica VM95E cartridge, an upgraded dampened aluminum anti-resonant platter, and a built-in preamp.
The $499 Fluance Ai81 Powered Tower Loudspeakers look very impressive on paper. But can they deliver sonically at that price?
The brand new Fluance RT85N Turntable comes with one of our favorite MM cartridges pre-installed but is it that much different than the RT85?
The best affordable turntables for Black Friday. We have some of the best performing for your money from Pro-Ject, Rega, U-Turn and more.
Fluance have announced its newest powered bookshelf speakers from the popular Ai Series, the Ai41 and Ai61. Affordable and available now for order.
Fluance just released their second budget home theater subwoofer called the DB10. At $200, it is $50 less and slightly less powerful than their...
