Fluance Has Expanded Its Reference Series with the Ri91 and Ri71 Powered Speakers
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Fluance Wireless Floorstanding Speakers Lifestyle
With so much financial uncertainty and ugly rhetoric back and forth between American and Canadian politicians right now, it has become somewhat dicey to delve into the trade war and impact of tariffs – but we have to deal with reality. We are huge proponents of Canadian high-end audio components and loudspeakers and we think Americans would be making a mistake crossing them off any lists. Buy quality – regardless of where it is made. Fluance has developed a reputation for making reasonably priced high-performance music systems and turntables. The Canadian manufacturer has added two new powered speaker systems to their product line, the Fluance Ri71 Reference Bookshelf Speakers and the Ri91 Reference Tower Speakers.
The Ri71 and Ri91 are powered systems where the “primary” speaker contains all of the amplification and connections and the “secondary” speaker connects via the supplied loudspeaker cables.
Fluance Wireless Bookshelf Speakers Front
Core Features of Both Systems
The Ri71 and Ri91 are a step up from the previously released Ai61 and Ai81. The amplifiers deliver the same wattage for bookshelf and floorstanding equivalents, but the Ri71 and Ri91 feature an AMT tweeter for greater high-end detail and superior off-axis performance, as well as elevated streaming music quality via Bluetooth aptX HD and HDMI ARC for easy setup and superior performance for TV listening. The HDMI-ARC feature enables listeners to use the Ri71 and Ri91 systems as soundbar substitutes.
Both the Ri71 and Ri91 powered speakers are designed to elevate the listening experience with advanced Air Motion Transformer (AMT) tweeters for crisp, detailed highs and custom-engineered waveguides for expansive sound dispersion. These components help to create an immersive soundstage, ensuring accurate reproduction of every instrument and vocal. The bass and treble response is adjustable via the provided remote or onboard controls.
Fluance Wireless Speakers AMT Tweeter
From Saied Swalee, Audio Engineer at Fluance: “Our new Reference Series Speakers are a testament to our commitment to fidelity, emphasizing sonic balance, intricate detail, and clarity in sound reproduction….This series appeals to the refined tastes of true sound connoisseurs, providing an unmatched listening experience without compromise.
Ri71
Fluance RI71 Wireless Bookshelf Speakers Lifestyle
Fluance RI71
The Ri71 bookshelf speakers combine a 120W amplifier with 5” woven glass fiber drivers, delivering a rich midrange and deep bass with a decrease in distortion levels. The rigid cone is designed to provide crystal clear, natural sound.
The Ri71 uses digital signal processing to enhance the vocal range, low-frequency response, and overall balance. The acoustically inert MDF wood cabinet, reinforced with internal bracing and a tuned front-firing port, enhances bass response and reduces unwanted resonance, ensuring a pure and natural sound profile.
Ri91
Fluance RI91 Wireless Floorstanding Speakers with App
Fluance RI91
Engineered for audiophiles and home theater enthusiasts, the Ri91 floorstanding speakers are designed to deliver room-filling sound with dual 6.5-inch woven glass fiber drivers. The drivers are supported by 150W Class D amplifiers and advanced Digital Signal Processing (DSP).
The precise tuning of the amplifier, drivers, crossovers, and cabinet ensures seamless signal alignment, and the speakers’ rigid structure produces clean, powerful low frequencies. The
MDF wood cabinet is designed to be acoustically inert and features extensive internal bracing.
Comparison
Fluance ModelRi91 Ai81 (2022)Ri71Ai61 (2021)
Speaker TypeFloorstanding Wireless SpeakerFloorstanding Wireless SpeakerBookshelf/Standmount Wireless SpeakerBookshelf/Standmount Wireless Speaker
Price (pr)$799.99$549.98$399.99$299.99
Speaker Configuration2.5 Way – 3 Driver Powered Floorstanding Speaker System with Integrated Amplifier (Pair – 1x Active, 1x Passive)Speaker Configuration 2 Way – 3 Driver Powered Floorstanding Speaker System with Integrated Amplifier (Pair – 1x Active 1x Passive)2-Way, 2-Driver Powered Bookshelf Speaker System with Integrated Amplifier (Pair – 1x Active, 1x Passive)2-Way – 2-Driver Bookshelf Speaker System with Integrated Amplifier (Pair – 1x Active, 1x Passive)
EnclosureTuned Front Firing Port Bass Reflex Design DampenedTuned Down-Firing Port Bass Reflex Design DampenedTuned Front Firing Port Bass Reflex Design DampenedTuned Rear Port Bass Reflex Design Dampened
Tweeter28 x 35 x 27mm x 33mm inch AMT (Air Motion Transformer)1-inch Silk Soft Dome Neodymium Ferrofluid Cooled28 x 35mm x 27mm x 33mm AMT (Air Motion Transformer)1-inch Silk Soft Dome Neodymium Ferrofluid Cooled
WooferDual 6.5 inch Woven, Glass Fiber Composite Drivers with Butyl Rubber SurroundsDual 6.5 inch Woven, Glass Fiber Composite Drivers with Butyl Rubber Surrounds5.25-inch Woven, Glass Fiber Composite Drivers with Butyl Rubber Surrounds6.5-inch Woven, Glass Fiber Composite Drivers with Butyl Rubber Surrounds
Amplifier TypeClass DClass DClass DClass D
Amplifier Power150 Watts Continuous Average Output (2 x 75 watts RMS)150 Watts Continuous Average Output (2 x 75 watts RMS)120 Watts Continuous Average Output (2 x 60 watts RMS)120 Watts Continuous Average Output (2 x 60 watts RMS)
Frequency Response40Hz – 30 Hz (DSP Enhanced)30Hz-20kHz (DSP Enhanced)46Hz – 30 kHz (DSP Enhanced)32Hz – 20kHz (DSP Enhanced)
Crossover Frequency2700Hz Asymmetrical 12 dB/Oct – PCB Mounted Circuitry2200Hz Phase Coherent 12dB/Oct – PCB Mounted Circuitry2700Hz Asymmetrical 12 dB/Oct – PCB Mounted Circuitry2800Hz Phase Coherent 12dB/Oct – PCB Mounted Circuitry
BluetoothYes, Bluetooth 5.0 aptX HDBluetooth 5.0Bluetooth 5.0 aptX HD, 192 kHz 24-bit, aptX Low Latency, SBC (Subband Codec), AAC (Advanced Audio Codec)Yes, BT 5.0
Audio Inputs2 x RCA L/R, Bluetooth, & HDMI ARC2x RCA L/R, Bluetooth, & Digital Optical TOSLINKRCA L/R, Bluetooth, & HDMI ARCRCA L/R, Bluetooth, Optical TOSLINK, USB Type-C
Internal Lead Wire18-Gauge Internal Lead Wire to Reduce Signal Degradation18-Gauge Internal Lead Wire to Reduce Signal Degradation18-Gauge Internal Lead Wire to Reduce Signal Degradation18-Gauge Internal Lead Wire to Reduce Signal Degradation
Subwoofer OutputYes, 80 Hz Low-pass Frequency CutoffYes, 80 Hz Low-pass Frequency Cutoff Yes, 80 Hz Low-pass Frequency CutoffYes, 80 Hz Low-pass Frequency Cutoff
Phono PreampNoNoNoNo
Internal DACYes, Up to 192 kHz 24-bit, THD+N ≤ 0.03% at 1 Watt, SNR ≥ 110 dB (A-weighted)YesYes, Up to 192 kHz 24-bit, THD+N ≤ 0.03% at 1 Watt, SNR ≥ 110 dB (A-weighted)Yes
WiFi CastingPairs via Bluetooth with Google Home, Amazon Echo, and AppleTV (Ri91 is not a WiFi speaker)Pairs via Bluetooth with Google Home, Amazon Echo, and AppleTV (Ai81 is not a WiFi speaker)Stream via Bluetooth with Google Home, Amazon Echo, and AppleTV (Ri71 is not a WiFi speaker)Pairs via Bluetooth with Google Home, Amazon Echo, and Apple TV (Ai61 is not a Wi-Fi speaker)
Total Harmonic Distortion (THD)No indicated<0.1% (THD+ N)<0.3% (THD+ N 1%)<0.3% (THD+ N 1%)
Power Input100-240V AC (50/60Hz)100-240V AC (50/60Hz)100-240 V AC (50/60 Hz)Input: 100-240V 50Hz/60Hz
Dimensions (HWD)41.73 x 8.5 x 10.24 inches / 106.0 x 21.6 x 26.0 cm37.8 x 8.50 x 10.24 inches / 96 x 21.6 x 26 cm12.20 x 7.28 x 7.83 inches / 31.0 x 18.5 x 19.9 cm 13.1 x 7.8 x 9.2 inches / 33.3 x 19.8 x 23.4 cm
Speaker WeightActive Speaker: 41.89 lb (19 kg)
Passive Speaker: 40.79 lb (18.5 kg)
Active Speaker: 30.61 lbs (13.88 kg)
Passive Speaker: 29.02 lbs (13.16 kg)
Active Speaker: 14.11 lb (6.4 kg)
Passive Speaker: 11.02 lb (5 kg)
Active Speaker: 14.03 lbs (6.36 kg)
Passive Speaker: 13.14 lbs (5.96 kg
FinishesWhite, Black, WalnutWhite Walnut, Black Ash, Luck Bamboo, Natural WalnutWhite, Black, WalnutWhite Walnut, Black Ash, Luck Bamboo, Natural Walnut
In the BoxRi91 Reference Stereo Floorstanding Speakers (pair)
Remote Control and Batteries
6ft. Power Cable
8ft 18-Gauge Speaker Wire
Quick Start Guide
Fluance Catalog
Lifetime Customer Support
2 Year Warranty
Ai81 Powered Floorstanding Speakers (pair)
6ft. Power Cable
8ft 18 Gauge Speaker Wire
Quick Start Guide
Fluance Catalog
2 Year Warranty
Ri71 Powered Bookshelf Speakers (pair)
6ft. Power Cable
Quick Start Guide
2 Year Warranty
Ai61 Powered Bookshelf Speakers (pair)
Remote ControlAnd Batteries
6ft. Power Cable
Quick Start Guide
Fluance Catalog
2 Year Warranty
Fluance RI71 Wireless Bookshelf Speakers Front and Back
The Bottom Line
Fluance continues to expand its speaker offerings with the Ri91 and Ri71 powered speakers, which offer some improvements over the previously released Ai81 and Ai61, such as the addition of AMT tweeters, HDMI-ARC, and phono compatible RCA analog inputs, but there are also some things that still make the Ai81 and Ai61 good options at lower price points.
On paper, the Fluance Ai81 and Ai61 have slightly wider frequency response, and although they don’t provide HDMI-ARC or phono-compatible RCA inputs, they do offer digital optical inputs, and the Ai61 has USB-C input connections, so it may be a toss-up as to which speaker system might work best for you.
The two new models do not feature internal MM phono pre-amplifiers which means that you will need to use a turntable with its own or an external phono preamp between the turntable and loudspeakers. We have a few affordable suggestions here
The downside is that these speakers don’t have built-in streaming (no WiFi) – so you need to access streaming content via your smartphone and pass it to the speakers via Bluetooth or connect an external media streamer.
Pricing & Availability
The Ri71 Reference Powered Bookshelf Speakers ($399.99) and Ri91 Reference Powered Tower Speakers ($799.99) are available in Black Ash, White Ash, and Walnut at Fluance.com.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
The Atelier program gives Bang & Olufsen's customers the chance to style their own speakers. The Beosound 2 Gradient Collection gets things started.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Audio Pro can add more style to your home entertainment system with new walnut finish on its A28 wireless speaker at $650 pair.
With both Bluetooth and wired connectivity, Onkyo's Creator Series GX10DB and GX30ARC Powered Speaker Monitors are a versatile and affordable compact audio solution.
