Fluance Introduces Affordable AB40 SoundBase
Fluance AB40 SoundBase
Fluance just introduced the AB40 High Performance Soundbase. The $250 under-the-TV-speaker is deeper than a standard soundbar, because it includes a downward firing subwoofer. The company says you’ll get room-shaking bass as low as 30Hz with an immersive and wide soundstage for an enveloping in-home cinema experience.
Fluance implemented 3D Sound technology that uses bass boost and psychoacoustics to calculate precise harmonics that are related to the fundamental tones of sound, virtually reproducing the lowest frequencies, just as if there was a subwoofer in the room. The result is a clean, deep bass performance you would expect from a full home theater system.
Fluance took its in-depth audio knowledge from years of home theater speaker engineering and used it to produce the high performance AB40 High Performance Soundbase. It features dual 1” high performance tweeters and four 3” aluminum lightweight, rigid drivers that produce cleaner vocals and dialogue at any volume for captivating, brilliant clarity; two of the drivers are positioned on opposing sides of the cabinet angled at 35 degrees to provide widespread sound throughout the entire room, allowing for every sound effect to be heard no matter where the listener sits in the room; and a 120W amplifier. In addition, the AB40 also has Bluetooth AptX technology to allow users to stream music wirelessly from any streaming source, such as Pandora, Spotify or iTunes.
The Fluance AB40 has been engineered with an acoustically tuned, MDF wood cabinet that produces a warm, more natural sound. The cabinet design allows for proper air flow so the drivers can perform at the highest level.
Price and Availability
The Fluance AB40 High Performance Soundbase is available now for $249.99 at Amazon or Fluance.com.
Specifications
SPEAKER CONFIGURATION 2 Way 6 Driver TV Soundbase with Integrated Amplifier
TWEETER Dual 1 inch Silk Soft Dome (Ferro Fluid cooled)
WOOFER Four 3 inch Aluminum Cone with Butyl Rubber Surround
FREQUENCY RESPONSE 30Hz – 20KHz
AMPLIFIER POWER (RMS) Class D (2x60w) 120 Watts Continuous Power
INPUT Digital Toslink Optical / 3.5mm Stereo AUX
BLUETOOTH Yes; aptX codec
VIRTUAL SURROUND SOUND (3D) Yes
BASS BOOST Yes
POWER Input: 100-240VAC, 50/60Hz 1.8A Output: 19VDC/3.15A
MAX WEIGHT ALLOWANCE 150 lbs
ENCLOSURE Tuned Side Port Bass Reflex Design
DIMENSIONS 3.9 x 26 x 14 inch
SPEAKER WEIGHT 24 lbs
CERTIFICATIONS ICES, FCC Certified, CUL/UL
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
The new turntable includes the Audio Technica VM95E cartridge, an upgraded dampened aluminum anti-resonant platter, and a built-in preamp.
The SVS Prime Wireless Pro SoundBase combines wireless media streaming with a two-channel integrated amplifier. Find out how this might fit in your home...
The $499 Fluance Ai81 Powered Tower Loudspeakers look very impressive on paper. But can they deliver sonically at that price?
The brand new Fluance RT85N Turntable comes with one of our favorite MM cartridges pre-installed but is it that much different than the RT85?
The best affordable turntables for Black Friday. We have some of the best performing for your money from Pro-Ject, Rega, U-Turn and more.
Fluance have announced its newest powered bookshelf speakers from the popular Ai Series, the Ai41 and Ai61. Affordable and available now for order.
