Florida Home Improvement Radio Show Demo House
Project Built from the Ground up Featuring Hard Wired High Definition Entertainment System
Josh Smith, producer for the In the House Radio Show, set out to demonstrate his show’s home improvement expertise by demolishing an existing two bedroom cottage and building a replacement house. Essential to the project was the mandate that the main entertainment center be located in the living room, hard wired for 5.1 surround sound, with an eye level, wall mounted flat panel television and no visible wires for power, audio and video using the HDMI format.
“The garage is equipped with air conditioning, an insulated door, plenty of storage for tools, as well as refrigerator hookups and a painted sealed floor, making it the perfect mans-cave,” explained Smith. “The garage has also been hard wired for a wall mounted TV, so we needed a way to allow for dual viewing of HDTV in the living room and the garage.”
With the installation of the audio/video system, Smith’s main goal was to avoid post-installation drilling or cutting into the finished drywall to run cables. “I also wanted to synchronize the garage’s A/V system to the living room to keep costs down,” said Smith. “We wanted the option to view the same content in both rooms without using two cable boxes. In these economic times its nice to save on a recurring monthly cost like cable and have the ability to share a single box.”
To allow for shared viewing in the garage and living room, Smith opted for the Gefen 1:2 Splitter for HDMI v1.3. Two long Gefen HDMI cables were hard wired into the walls for HDTV connectivity. “The HDMI cables used in the walls add a clean look to the A/V setup with no visible wires connecting the television to the cable box or power,” he explains.
After the in-wall wiring was complete, the drywall was mounted and the audio/video installation finalized. “The A/V portion of the install went perfectly,” he says. “And the Gefen splitter allows for dual viewing in the living room and garage, which is exactly what we wanted.”
Smith performed the A/V installation himself, working with Universal Roofing and Construction, the principal contractor who created the framing to support the system as well as possible expansion in the future. “After the house is completed, this system will allow for the ability to watch a home surveillance system in the garage as well as in the living room.”
Although the In the House radio show has covered kitchen, bath, patio and living room remodels in the past, it has not handled a whole house remodel until now. “So this was the perfect opportunity to give our listeners a taste of what its like to totally rebuild a house. It’s been challenging, at times, but also a lot of fun.”
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
