FiiO’s KB3 Hi-Fi Keyboard Will Drive Your Headphones As You Work
For those looking to maximise their desktop space and enjoy hi-res music as they work through a pair of headphones, the FiiO KB3 Hi-Fi Keyboard is no gimmick.
Give FiiO some credit. Not only have they released some of the best new DAPs, Dongle DACs, and headphones in 2023, but this is one brand thinking outside of the traditional high-end audio shipping box.
Desktop audio has become a rather big category and with so many consumers working from home — there is a need for products like the FiiO KB3 Hi-Fi Keyboard that serves as a fully functional keyboard compatible with Windows, MacOS, Android, and iOS that incorporates two high-performance and efficient CS43131 DACs, as well as two low-noise SGM8262 op-amps so that you can connect your headphones directly to the keyboard.
FiiO KB3 Hi-Fi Keyboard Desktop Lifestyle
One less box on your desktop, and more than enough power for some rather popular audiophile headphones; especially FiiO’s new FT3 32 Ohms model.
Capable of providing up to 550mW of output power — supporting audio files up to 32-bit/384kHz and DSD256 — and equipped with both 3.5mm single-ended and 4.4mm balanced headphone outputs, a wide variety of headphones can be connected to the KB3.
The FiiO KB3 features a gasket mount design, made up of multiple layers, which serve to greatly absorb shocks, thereby reducing noise.
FiiO KB3 Hi-Fi Keyboard with Laptop
Thanks to its Gateron G Pro 3.0 yellow switches, the FiiO KB3 is perfect for both productivity and gaming.
With semi-transparent swappable key-caps, multiple preset options of RGB lighting, built-in step-less volume control and – thanks to dual USB connections – the ability to act as a docking station for mouse, USB drives etc., the KB3 Hi-Res Hi-Fi Keyboard with built-in DAC/Amp is a truly versatile addition to your desktop set-up.
Specifications
Headphone Outputs1 x 3.5mm Single-ended
1 x 4.4mm Balanced
DAC2 x Cirrus Logic CS43131
Op Amp2 x SGMICRO SGM8262
USB ChipSavitech SA9312L
Output Power (3.5mm)L+R≥170mW+170mW (32Ω, THD+N<1%, USB IN)
Output Power (4.4mm)L+R≥550mW+550mW (32Ω, THD+N<1%, USB IN)
SNR≥122dB (32Ω A-weighted)
Noise Floor2.5uV (A-weighted)
THD+N<0.0005% (0dB, 32Ω)
Supported OSWindows / MacOS / Android / iOS
USB Connections1 x USB-C 2 x USB-A
Dimensions (H x W x D)43.5mm x 329mm x 140mm
Weight1.06kg
Colour OptionsMidnight Black / Morning Silver
FiiO KB3 Hi-Fi Keyboard is available in black or silver
Where to buy: $129.99 at AliExpress
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
