Dongle DACs
FiiO’s KA15 Dongle DAC Supports Hi-Res Playback With a Rather Unique Retro Look
At $109, the FiiO KA15 is a retro inspired dongle DAC that looks like a mini cassette player, but there’s no tape involved.
FiiO KA15 'Cassette Player' Dongle DAC
FiiO has established itself as one of the premier manufacturers in the high-end headphone space with a focus on DAPs and headphone amplifiers that offer excellent sonic performance and value for the money. The past 12 months has seen them pivot somewhat with the release of loudspeakers, headphones, network players and portable Cassette and CD players that deliver a rather unique retro look aside from their technical capabilities. The new FiiO KA15 USB DAC/Headphone Amplifier offers a little of both.
Building on its previously released USB DAC products such as the KA13 and BTR13, the KA15 is for anyone seeking improved audio quality on the go with wired headphones. Just connect it between a smartphone, tablet, laptop or gaming device and a wired headphone.
The KA15 transforms any mobile device into a high-end audio system with enhanced features, premium components, and cutting-edge technology.
FiiO KA15 'Cassette Player' Dongle DAC Black
FiiO KA15
FiiO claims that KA15 takes portable digital-to-analog converters (DACs) and headphone amplifiers to a higher level. Featuring dual Cirrus Logic CS43198 DAC chip architecture and a high-performance THX AAA-78 amplifier, the KA15 is designed to deliver elevated sound quality with clarity, detail, and wide dynamics that meet the demands of both professional and enthusiast listeners, all in a pocket-size device.
The KA15 features a 0.96-inch LCD IPS display screen that not only displays status information but has a retro look reminiscent of the tape window on a portable cassette player. It also has an RGB LED indicator, which changes color based on the audio file’s bitrate or format being played. This provides users with instant feedback on their listening experience.
FiiO KA15 in sky blue and midnight black
FiiO KA15 is available in sky blue or midnight black.
Key Features
Powered by two Cirrus Logic CS43198 DAC chips, the KA15 is designed to deliver digital audio conversion for hi-res audio up to 32-bit/768kHz PCM, native DSD512, and MQA decoding.
The KA15 incorporates a THX AAA-78 amplifier, which provides near-zero distortion and high output power for clean, uncolored sound.
The KA15 is equipped with USB-C input and a variety of output options, including a 3.5mm single-ended jack and a 4.4mm balanced output. This ensures compatibility with a wide range of headphones and earphones, from casual to high-end models.
The KA15 features multiple gain settings (low, medium, and high) and a low-power mode, allowing users to adjust the output depending on their headphones’ impedance or to conserve battery life during mobile use. For further sound tweaking a 10-band parametric EQ is accessible via the FiiO Control app for iOS and Android.
FiiO KA15 App
Tip: At this time, the KA15 Control App is only available on Android version.
At just 50 grams, the KA15 is one of the most compact high-end DAC/amps available, making it perfect for users who prioritize portability without sacrificing performance.
The FiiO KA15 is designed to work with tablets, laptops, and game consoles. It works with both streaming content (via USB-C connection from a smartphone) and local files. The KA15’s power management system supports the delivery of high-fidelity sound without draining the battery of connected devices, extending the battery life of your phone.
Adjustable gain settings allow fine-tuning of output to match different headphones and earphones. The 4.4mm balanced output provides the highest possible sound quality for those using balanced headphones, while the 3.5mm jack ensures broad compatibility for most users.
Comparison
FiiO KA15 vs. BTR13 Dongle DACs
FiiO KA15FiiO BTR13
Price$109.99$69.99
DACCirrus Logic CS43198 x 2Cirrus Logic CS43131 x 2
Bluetooth ChipsetN/AQualcomm QCC5125 (CPU + DSP Dual-core Architecture)
Bluetooth VersionN/A5.1
Bluetooth CodecsN/ASBC, AAC, aptX, aptX LL, aptX Adaptive, aptX HD, LDAC
Display0.96-inch 80×160 color IPS0.96-inch 80×160 color IPS
Headphone Outputs4.4mm Balanced
3.5mm Single-Ended
4.4mm Balanced
3.5mm Single-ended
Output Power (Single-ended)L+R≥180mW+180mW (32Ω, THD+N<1%, USB IN)L+R≥100mW+100mW (32Ω, THD+N<1%)
Output Power (Balanced)L+R≥560mW+560mW (32Ω, THD+N<1%, USB IN)L+R≥220mW+220mW (32Ω, THD+N<1%)
Frequency Response20Hz~20kHz20Hz~40kHz (-3dB)
Output Impedance<0.8Ω<0.6Ω
Signal to Noise Ratio (SNR)≥122dB (32Ω, A-weighted)≥128dB (A-weighted)
THD+N<0.0004% (-4dB, 32Ω)(1kHz/-4dB@32Ω)
Noise Floor1.7uV”A”<1μV (A-weighted
Power SupplyUSB Bus Powered, Low-Power ModeUSB Bus, Battery
Charging TimeN/A≤2 hours
Battery LifeN/A8 hours
Dimensions65 x 24 x 13 mm
(2.56 x 0.95 x 0.51 inches
63.2 x 30 x 18.8mm
(2.49 x 1.2 x 0.75 inches)
Weight50 grams
(1.8 oz)
28.6 grams
(1.1 oz)
ColorsMidnight Black
Sky Blue
Black
Blue
FiiO KA15 with CP13 Cassette Player in Background
FiiO KA15 with CP13 Portable Cassette Player in background.
The Bottom Line
The FiiO KA15 portable Headphone Amp/DAC stands out in a field of rather plain looking dongle DACs. Its cool factor alone makes it worthy of a closer look, and it is likely to capture the attention others when used in public.
Ultimately, its sound quality will determine its viability. There are other less expensive options — even from FiiO itself — such as the aforementioned BTR13 as well as the Questyle M12i which may sound better.
Either way, we applaud FiiO’s innovation in the portable DAC/Headphone Amp product category and think the KA15 could make for a great stocking stuffer this holiday season.
Price & Availability
The FiiO KA15 will be available now in sky blue or midnight black for $109.99 at Amazon.
For more information: fiio.com/KA15
Related Reading
1 Comment
1 Comment
  1. ORT
    October 7, 2024 at 6:53 pm
    So then…MQA is on the gnu FiiO KA15? When they announced the KA5 as being free of the gluten that is MQA, I immediately purchased one.
    I was ready to buy the K15 but since they decided to pack it with MQA crap (as opposed to Schiit!) I ain’t gonna do dat. I just checked FiiO’s own website page on the KA15 and found no mention of MQA.
    If they made a mistake and it doesn’t have MQA then I shall reign down upon them the munificence of my forgiveness. And purchase one.
    If it really does have the turd known as MQA I suggest they change the model designation to KAKA15.
    ORT
2026 Campfire Audio Cascara Mk2 IEMs
At $549, Campfire Audio Cascara Mk2 IEMs retain its 10mm dynamic driver with revised tuning, a new design, and upgraded accessories.
2026 Eversolo DAC-R8 and C10 Master Clock 2026 Eversolo DAC-R8 and C10 Master Clock
Eversolo's $1,280 DAC-R8 packs proprietary R2R conversion and serious DSP, while its $1,880 C10 promises precision clocking. Is the extra box worth it?
2026 SOUNDPEATS AIR6 PRO Earbuds Lifestyle 2026 SOUNDPEATS AIR6 PRO Earbuds Lifestyle
SOUNDPEATS Air6 Pro earbuds combine aptX Lossless, Dolby Audio, adaptive ANC and new sound tuning at a budget price. Can they outperform pricier rivals?
2026 Chord Electronics ULTIMA 7 Stereo Power Amplifier Front Angle Black 2026 Chord Electronics ULTIMA 7 Stereo Power Amplifier Front Angle Black
Priced over $10K USD, Chord Electronics ULTIMA 7 stereo power amplifier combines 140-watts per channel of Class G power, with dual feed forward error...
2026 Grado GW200 Open-Back Wireless Headphones 2026 Grado GW200 Open-Back Wireless Headphones
Grado's GW200 takes a different approach to wireless headphones with new S drivers and aptX Lossless. Could this be what open back enthusiasts have...
2026 Klipsch Stratos HP-3 and HP-2 Headphones 2026 Klipsch Stratos HP-3 and HP-2 Headphones
First previewed at the 2026 CES and High End Vienna under the Atlas name, Klipsch brings the final versions of the HP-2 and HP-3...
Black Friday Gift Guide 2026
Black Friday gift ideas and real deals on headphones, speakers, hi-fi and home theater you'd actually enjoy at the lowest prices all year.
From affordable USB-C adapters to premium balanced DACs and versatile Bluetooth hybrids, our 2026 Editors' Choice picks reveal which portable DAC/headphone amplifiers are worth...
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
FiiO's $380 CLASS A headphone amp can switch to Class AB with low-impedance headphones. Here's what FiiO says and why the distinction matters.
Over-Ear Headphones
The $160 FiiO JadeAudio JT9 planar headphones deliver deep bass and spacious sound, but can their bright treble spoil an otherwise excellent value?
Eversolo brings 180 watts of Class AB power while FiiO answers with EL34 tubes and pure Class A. Two Chinese amplifiers, two very different...
CD Players
FiiO’s $170 DP11 adds AES, a CS43198 DAC, CD ripping and USB conversion because apparently nobody told the compact disc it was dead.
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
