DAPs
FiiO’s JM21 DAP is Super Affordable But Who is the Target Buyer?: CES 2025
The FiiO JM21 portable digital audio player supports high-quality music playback at an extremely low price.
FiiO JM21 DAP Lifestyle
Very few manufacturers within the portable and desktop audio categories were as busy as FiiO in 2024 — from the flurry of new product announcements at CES 2025 this morning, it would be appear that the next 12 months might be even busier for the popular brand.
FiiO went off the reservation somewhat last year with the introduction of a portable cassette player and CD player; we were so impressed with the new FiiO DM13 that it made our “Best CD players: Editors’ Choice” list for 2024.
CES 2025 is underway and they have just pulled back the curtains on the new FiiO JM21 DAP (Digital Audio Player) for only $199 USD. [Price was updated by FiiO on 01/16/2025]
The new DAP is part of a trio of new digital streaming products from FiiO that includes the K17 headphone amplifier and S15 network streamer.
FiiO JM21
FiiO JM21 DAP front and back
At first glance, the FiiO JM21 DAP looks like a great deal at only $149; the market has been moving the other direction in recent years and this new player featuring an ultra-slim 13mm chassis, and running on Android 13 and FiiO’s UI could be the DAP that makes consumers finally take notice of the category.
Before we delve further into the weeds and discuss the rather obvious question that has been foremost in our mind this morning, let’s take a look at what FiiO has packed into the rather slim case.
Hear Ealan Osborne’s narrated version of this article on YouTube.
Dual CS43198 DACs (one for balanced output and one for single ended output) are combined with 3GB RAM and 32GB of internal storage. With a 3.5mm and balanced 4.4mm headphone socket and FiiO Music on board, all high-res streaming services are supported and a MicroSD slot offers extensive storage options for digital music collections up to 2TB.
It is truly pocket-sized at just 165 grams, it could be the ideal travel companion with 12 hours of battery life and a two-hour fast charge mode.
From a power perspective, the FiiO JM21 offers 360mW (16Ω, THD+N<1%) and 245mW (32Ω, THD+N<1%) from its single-ended 3.5mm output which will make it compatible with easier to drive IEMs and headphones; Grado fans should do well here.
The power output drops rather dramatically once we start looking at headphones or IEMs above 300 ohms; don’t expect more than 30mW at this level.
The balanced output offers 605mW (16 ohms) and 700 mW (32 ohms) which will increase the range of headphones and IEMs that one can use with it to satisfactory volume levels. The output above 300 ohms falls to 80mW.
FiiO JM21 DAP dimensions
 JM21 Specifications
Qualcomm Snapdragon 680Yes
DAC CS43198 x 2
AmplificationSGM8262 x 2
Operating System Android 13
Op AmpSGM8262 x 2
RAM and Storage3G RAM+32GB ROM
Storage ExpansionMicro SD Slot up to 2 TB
Bluetooth Version5.0
Wi-Fi 2.4GHz/5GHz,Supports DLNA, AirPlay, WiFi song transfer, etc.
USB DAC: Up to 384kHz/32-bit; DSD256 (Native)
Local DecodingUp to 384kHz/32-bit; DSD256 (Native)
USB Audio768kHz/32-bit; DSD512 (DoP/D2P/Native supported)
Digital Coaxial OutputUp to 384kHz/24-bit; DSD128 (D2P/DOP)
OutputsSingle Ended 3.5mm PO/SPDIF  + Balanced 4 ohms
Display Size4.7-inch (750×1334) bezel-less display
Dimensions4.75 x 2.68 x .05 inches
The Bottom Line
2024 was a rather slow year for new DAP introductions and we saw the big players like FiiO, Astell&Kern, and Cayin focus on the upper end of the market. Our “Best DAP” selection from Astell&Kern is a reflection of that trend within the category.
So what should consumers make of the FiiO JM21?
It offers support for a rather wide range of hi-res formats and can also be used as your network player through its digital coaxial and 3.5mm outputs.
Bluetooth support for AAC, SBC, aptX, aptX HD, LDAC, and LHDC will also broaden its appeal.
The power output specifications will certainly influence what one can connect on the other end but the balanced output option certainly widens the net.
Digging deeper into the specifications, we noticed that the battery requires 2 hours to achieve a full charge and the one should expect up to 12.5 hours of playtime using the single-ended output and 9.5 hours through the balanced output; both of those claims are with the DAP on its high gain setting, but running MP3s or 16-bit/44.1kHz PCM files.
The benefit of using a DAP over your existing smartphone connected to a Dongle DAC is that you have more space for your music, support for a wider range of hi-res formats and Bluetooth codecs, and it doesn’t drain your phone’s battery — which is a negative of a number of Dongle DACs used to stream hi-res files driving more demanding IEMs and headphones.
At $199, the FiiO JM21 appears to be a rather affordable gateway drug into the DAP category.
Pricing and Availability
The FiiO JM21 is available now for $199 at Amazon (149 EUR/ £139). For more information, visit: fiio.com/jm21.
2 Comments
2 Comments
  1. Tybur Visarion
    January 12, 2025 at 11:06 pm
    The only reason like the sole reason that I don’t want it, even though I might end up getting it just because it’s so cheap, is it doesn’t have an analog scroll wheel. at this point I will buy something even if it sucks just because it has a scroll wheel because I just want that tactile feedback
    And in case fiio somehow is looking at this, know a haptic button that doesn’t actually do anything does not count. even if it feels like one mentally, I know it’s not and that’s what matters
  2. Karl
    January 13, 2025 at 3:56 am
    This looks good. Could we have a comparison with the smaller sized,longer playing, slightly lower spec’d HiBy M300? The HiBy seems to fit my portable use profile (don’t need 4.4mm).
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
FiiO expands its line-up with K17 Headphone Amp, which provides a lot of features and connectivity that raise the price, but should please any...
