FiiO’s FT3 32Ω Headphones are Ideal for Dongle DAC Users
The FT3 32Ω Edition in Black, together with a new White version of the original FT3, both available this month for £289/$299/€299
FiiO FT3 32-ohm open-back headphones in black and white
The astounding growth of the Head-Fi revolution has created a lot of opportunities for Chinese manufacturers to develop products that often offer superior performance to their rivals from North America and Europe. When you look at the quality of the products coming out of FiiO, Questyle, Xduoo, HiFiMAN and Cayin — it’s clear that there are a lot of talented domestic engineers.
Music listeners have benefitted enormously when you consider the availability of so many affordable IEMs, DAPs, Dongle DACs, and headphones from these companies.
FiiO launched its first pair of over-ear open-back headphones, the affordable FT3, earlier this year and they offer an amazing level of performance at their price. Whilst some were probably surprised to see the FT3, the reality is that FiiO has a strong track record of creating superb IEMs and these open-back headphones were on the drawing board for awhile.
The FT3 have already been a success for FiiO but there were some who felt that they could have created different color ways and a model that was easier to drive.
Meet the FiiO FT3 32Ω Headphones.
FiiO FT3 32Ω Open-back Headphones Black
FiiO FT3 32Ω Edition
Featuring 60mm Dynamic Drivers; 3.5mm Singled-ended, 4.4mm & XLR Balanced Audio Plugs; Interchangeable Suede and Leather Earpads; and Monocrystalline Copper Cable, the FiiO FT3 have proven a huge success with audio fans around the world.
Now, expanding the FT3 line-up, FiiO announces two new models: The FT3 32Ω Edition in Black, together with new White version of the original FT3.
Just like the original FiiO FT3, the upcoming FT3 32Ω Edition is an open-back pair of headphones featuring large 60mm Dynamic Drivers, housed in an aluminum alloy shell that is both strong and lightweight, weighing in at just 391 grams.
FiiO FT3 open-back headphones in white
FiiO FT3 350Ω Edition
However, whereas the original FT3 was rated at 350 ohms, the FT3 32Ω Edition comes in at just 32Ω. This allows these headphones to be easily driven by lower-powered DAPs, Headphone DACs, and smartphones.
To deliver a large 60mm dynamic driver that would still be easy to drive with this low 32Ω resistance, the engineers at FiiO tested several materials for the driver diaphragm.
They opted for the FT3 32Ω Edition to utilize an LCP Aluminum-plated + Aluminum Metal Composite diaphragm.
FiiO FT3 32-ohm open-back headphone ear cups side in black and white
Both the FT3 and FT3 32Ω Edition both come supplied with a with a set of interchangeable connector plugs. Choose from 3.5mm and 6.35mm (single-ended) or 4.4mm and XLR-4 (balanced) – enabling these headphones to be enjoyed with everything from Digital Audio Players (DAPs) and smartphones; PCs and FiiO’s own next-gen desktop hi-res audio player, the R7 which was introduced earlier this year.
FiiO FT3 32Ω Edition Interchangeable Connector Plugs
Both the FT3 and FT3 32Ω Edition featuring a 3-axis swivel design to provide the best fit and their drivers are also placed at an angle, ensuring they are parallel to the ear when worn.
This not only serves to assist in reducing any high-frequency response distortion, caused by sound waves hitting the contour of the ear and not entering it; but also minimizes any those reflections caused by the shell of the headphone that can lead to standing waves and further unwanted distortion.
Comparison
FT3FT3 32Ω Edition
Colour OptionsBlack / WhiteBlack
Headphone TypeOpen-backOpen-back
Driver TypeDynamicDynamic
Driver Size60mm60mm
Driver Diaphragm MaterialBeryllium-plated Gasket with Diamond-Like Carbon (DLC)LCP Aluminium Metal Plated & Aluminium Metal Diaphragm
Frequency Response7Hz – 40kHz7Hz – 40kHz
Sensitivity105dB (1Vrms) @1kHz110db (1Vrms) @1kHz
Impedance350Ω32Ω
Cable Length3m1.5m
Cable MaterialFurukawa Monocrystalline Copper392 Wire High-PuritySilver-plated MonocrystallineCopper Cable
Detachable CableYesYes
Cable ConnectorsDual 3.5mmDual 3.5mm
Cable Plug Connectors3.5mm (Single-ended)
4.4mm (Balanced)
6.35mm (Single-ended) (Via Supplied Adaptor)
XLR-4 (Balanced) (Via Supplied Adaptor)
4.4mm (Balanced)
Weight391g (Excluding Cable)391g (Excluding Cable)
Earpad Pressure4.0N±0.3N4.0N±0.3N
Supplied Accessories1 x 3.5mm Single-ended Interchangeable Plug
1 x 4.4mm Balanced Interchangeable Plug
1 x 3.5mm to 6.35mm Single-ended Adaptor
1 x 4.4mm to XLR-4 Balanced Adaptor
1 x Headphone Cable
1 x Removable Protein Leather Earpads (Pair)
1 x Removable Suede Earpads (Pair)
1 x Leather Storage Case
1 x Instruction Booklet
1 x Headphone Cable
FiiO FT3 32-ohm open-back headphones black front
Price & Availability
Supplied with 2 pairs of removable ear-pads — one pair suede, one pair leather — and a leather carry case the FiiO FT3 (White), and new FiiO FT3 32Ω Edition, open-back headphones are available for $299 at Amazon, £289 at Amazon.co.uk and $466 at Amazon.ca.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
Over-Ear Headphones
For under $600, the DT 1770 Pro MKII closed-back studio headphones are a more refined and textured update of a classic studio can.
Apple is adding Lossless Audio and Ultra-Low Latency to the AirPods Max Headphones, but only when wired.
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
