Preview: FiiO’s FT1 Closed-Back Headphones Look Like A Great Deal For Only $149
Affordable wired over-ear headphones feature American black walnut wooden ear-cups with 2nd generation 60mm dynamic drivers.
FiiO FT1 Closed-back Walnut Headphones with Case
Following up on the recently released FH19 in-ear monitors, FiiO has circled back with the release of its FT1 Closed-Back Headphones.
The FT1 is the latest in FiiO’s FT over-ear wired headphone range which includes the FT3 and FT5.
FiiO’s goal with the FT1 is to offer a stylish and comfortable headphone with good sound quality at a very affordable price. Let’s take a closer look.
FiiO FT1 Overview
In terms of style, the FT1 incorporates real American Black Walnut Wooden Ear-cups. For all-day wearing comfort the FT1 has breathable fabric earpads. The high-density breathable mesh design efficiently dissipates heat buildup between the ear cushions and your ears. The side of the ear cushions is made of protein leather.
FiiO FT1 Closed-back Headphones Angle and Side Views
The FiiO FT1 ear-cups are made from FAS-grade American Black Walnut. The wood’s smooth grain is unique to each pair of FT1s, and this highly dense solid wood helps to effectively reduce cavity resonance and minimize standing waves. Inside the earcups and behind the fabric earcups, the FT1 incorporates a second-generation 60mm dynamic drivers.
Its larger-than-average size enhances energy conversion efficiency and provides support for solid bass response. The larger size also results in lower low-frequency resonance points, ensuring a deeper dynamic bass response.
FiiO FT1 Closed-Back Headphones Driver Construction
The FT1’s diaphragm consists of paper wood fibers, and light PU (Polyurethane) is used in the W-shaped suspension gasket. This enables high internal resistance, which supports better sound quality.
The FT1 incorporates an imported Japanese ultra-fine CCAW (Copper-Clad Aluminum Wire) Voice Coil with a diameter of up to 25mm.
A longer voice coil copper wire can directly enhance transducer efficiency and drive capacity, improving transient response and resulting in purer, more comfortable sound.
Each wire core in the CCAW coil has a diameter of approximately 0.035mm.
A U-shaped sound Damping Tube developed for the FiiO FT1 not only enhances passive noise attenuation but also allows sound energy to pass through at a specific length and angle. This increases air viscosity and reduces cavity resonance frequency contributing to providing more effective bass extension.
FiiO provides a Conical Baffle Plate for the FT1 drivers. This means that the driver is positioned parallel to the human ear; breaking up sound convergence and avoiding standing waves.
This results in minimal high-frequency attenuation, further enhancing sound quality.
To ensure the new FT1 can be used with PCs and Macs, Digital Audio Players, FiiO’s new portable CD and cassette players, and more, there are two interchangeable headphone cables included: a 3.5mm single-ended plug, and a 4.4mm balanced plug.
FiiO FT1 Closed-Back Headphones Wired Connectors
Both cables contain Oxygen-free Copper-plated Silver Wire with 392 wires. This helps to support a transparent and robust sound signature.
The FT1 uses the same ergonomic headband design found on the FT3 and FT5 Open-back headphones. The 3-axis Adaptive Headband allows for free rotation at multiple angles, ensuring a comfortable, snug fit with minimal sound leakage.
There are 12 levels of fit adjustment; the horizontal rotation angle is 35°, the pitch rotation is 45°, and the sliding travel of the headband is 38mm.
Comparison
FiiO FT1, FT3, FT5 Headphones Comparison
FT1FT3 (350 ohms)FT3 (32 ohms)FT5
Price$149$299$299$449
Headphone TypeClosed-back DynamicOpen-backOpen-backOpen-back Planar Magnetic
Ear-cup MaterialAmerican Black WalnutAluminumAluminumAluminum
Ear-pad Pressure4.5N±0.3N4.0N±0.3N4.0N±0.3N4.0N±0.3N
Driver60mm Dynamic60mm Dynamic60mm Dynamic90mm Planar Magnetic
Frequency Response10Hz-40kHz7Hz-40kHz7Hz-40kHz7Hz-40kHz
Impedance32Ω350Ω32Ω36 Ω
Sensitivity113dB (Vrms) @1kHz105dB (1Vrms) @1kHz110db (1Vrms) @1kHz110db (1Vrms) @1kHz
Cable MaterialSilver-plated Oxygen-free CopperFurukawa Monocrystalline Copper392 Wire High-PuritySilver-plated MonocrystallineCopper Cable392-wire High-purity Silver-plated
Cable Length1.5M3m1.5m1.5m
Headphone ConnectorsDual 3.5mmDual 3.5mmDual 3.5mmDual 3.5mm
Weight340g (Excluding cable)391g (Excluding Cable)391g (Excluding Cable)456g (Excluding Cable)
Supplied Accessories1 x Storage Bag
1 x 3.5mm Single-ended Headphone Cable
1 x 4.4mm Balanced Headphone Cable
1 x 3.5mm to 6.35mm Adaptor
1 x Quick-start Guide
1 x Leather Storage Case
1 x 3.5mm Single-ended Interchangeable Plug
1 x 4.4mm Balanced Interchangeable Plug
1 x 3.5mm to 6.35mm Single-ended Adaptor
1 x 4.4mm to XLR-4 Balanced Adaptor
1 x Headphone Cable
1 x Removable Protein Leather Earpads (Pair)
1 x Removable Suede Earpads (Pair)
1 x Instruction Booklet
1 x Headphone Cable
1 x Removable Suede Earpads (Pair)1 x Instruction Booklet
1  x 3.5mm Single-ended Interchangeable Jack Plug
1 x XLR-4 Male to 4.4mm Female Balanced Adapter
1 x 6.35mm Male to 3.5mm Female Adapter
1 x Velvet Bag
1 x Protein Leather Earpads (Pair)
1 x Suede Earpads (Pair),1 x Headphone Cable
1 x User Manual
FiiO FT1 Closed-Back Headphones Side
Initial Impression
If you prefer over-ear or on-ear closed-back headphones, the new FiiO FT1 look like a rather compelling option for only $149. If they offer a similar level of performance of their more expensive siblings — these could be a steal.
The walnut earcups are not typical at this price point, and we rather like the design overall.
But what matters is how these perform in a very crowded market against some good options from Grado Labs, Sennheiser, Beyerdynamic, and HiFiMAN.
Based on our experience with their other models, the FiiO FT1 could be one to consider at the rather low asking price.
FiiO FT1 Closed-Back Headphones in American Black Walnut
FiiO FT1 Closed-Back Headphones Beech Edition
Price & Availability
The FiiO FT1 is available for $149 at Amazon (USD) in walnut, as well as internationally for £139 or €159 through authorized sellers.
A FT1 beech wood edition is expected in October 2024.
For more information: fiio.com/ft1
Related Reading
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
