Dongle DACs
FiiO’s BTR7 Hi-Res Portable Dongle DAC Offers Wireless Playback
The Bluetooth enabled FiiO BTR7 Dongle DAC offers support for DSD, MQA, and features single-ended and balanced outputs.
FiiO BTR7 Connected to MacBook
Yet another Dongle DAC. Before you feel the urge to yawn, the design and features of the FiiO BTR7 makes us think that this might be one really worth considering. The $199 USD price is also a positive development with some premium Dongle DACs going for significantly more.
A truly multi-functional device, the BTR7 offers the option of wired or wireless transfer of your audio, via either USB or Bluetooth. With support for a wide range of Bluetooth codecs, including aptX HD and LDAC, the BTR7 not only offers compatibility with multiple devices, it is able to wirelessly decode high resolution audio up to 24-bit/96kHz.
FiiO BTR7 Portable Bluetooth Amplifier
Sharing design cues with other FiiO products, such as the excellent M11S Portable Music Player that we just reviewed, the BTR7 features a 1.3-inch color screen that displays information including audio bitrate, volume level, Bluetooth codec and more. ​
The BTR7 is the first portable Bluetooth amplifier to utilise two THX AAA-28 amplifiers. As a result, FiiO have have been able to deliver a fully-balanced audio design, with each channel being driven separately. The BTR7 is able to deliver 88% more single-ended power output and 30% more balanced power output compared to previous models.
When it comes to audio quality, dynamic range, and overall musicality, FiiO have adopted a dual DAC chipset design for the BTR7. Featuring two ESS9219 Sabre DACs, with a 32-bit ‘HyperStream’ architecture, the BTR7 delivers a SNR (Signal to Noise Ratio) of 118dB via both the featured 3.5mm single-ended and 4.4mm balanced headphone outputs.
FiiO BTR7 Connected In Car
Alongside its ability to receive audio via Bluetooth, the FiiO BTR7 can be used in a wired configuration as a portable USB DAC/Amplifier by accessing the ‘One-Click Dongle Mode’. Simply connect your smartphone, laptop or other compatible device to the BTR7 via the USB-C cable.
One press of the charge button will allow the BTR7 to switch in and out its USB dongle mode, allowing you to enjoy audio files up to 32-bit/384kHz (PCM) or DSD256 – including those featuring MQA – in the highest quality. ​
Compared to some other USB dongles available, the BTR7 does not consume your smartphone’s battery power whilst in this mode.
In order to enable wider compatibility with different devices, the FiiO BTR7 features the ability to switch the USB to a USB 1.0 driverless interface. This allows the BTR7 to work with older devices — or devices with locked operation systems — such as the Sony PS5 and Nintendo Switch.
FiiO BTR7 Connected to gaming device
In addition to viewing the BTR7’s menu on its built-in 1.3-inch color screen, functions and settings can also be accessed in the dedicated ‘FiiO Control’ app, available for both Android and iOS smartphones. The FiiO Control app allows for a number of additional features, including firmware updates and a 10-Band Graphic Equalizer.
Key Features:
  • Bluetooth DAC & USB DAC Functions
  • One-Click Dongle Mode (USB DAC/Amplifier)
  • Dual ESS Technology Sabre ESS9219 DACs
  • Dual THX AAA-28 Amplifiers
  • 1.3″ 240×240 IPS Colour Display
  • Qualcomm QCC5124 Bluetooth Chip with Bluetooth 5.1
  • Bluetooth Codec Support: AAC/SBC/aptX/aptX LL/aptX Adaptive/aptX HD/LDAC
  • Support for audio files up to 32-bit 384kHz PCM / DSD256
  • MQA Support
  • Headphone out: 1 x 3.5mm Single Ended / 1 x 4.4mm Balanced Output
  • Up to 9 Hours Battery Life
  • Wireless Charging (Qi Standard)
In the Box:
  • 1 x FiiO BTR7 Portable Amplifier
  • 1 x Black Leatherette Case
  • 1 x Type-A to Type-C USB Charging Cable
  • 1 x USB Type-C to Type-C Cable (included in both versions)
  • 1 x USB Type-C to Lightning Cable (included in BTR7 Lightning version only)
  • 1 x Quick start guide
Price & Availability
The FiiO BTR7 (USB-C Version) is available now priced, £175 / $199. The FiiO BTR7 (Lightning Version) is available now priced, £195 / $209.
Where to buy: $199 / $209 at Amazon
1 Comment
1 Comment
  1. James D
    January 10, 2023 at 8:52 pm
    I have this, as well as the similar but smaller and more affordable Qudelix 5k. As a wired DAC driving my headphones the BTR7 has been absolutely great. Sounds good, plenty of power, no driver struggles. It also works plug and play with my iPad and phone. I’d say the main downside is it’s pretty bulky for pocket use which is why I decided keep the 5k as well.
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Earbuds & In-Ear Headphones
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
Dongle DACs
Does the iFi GO Bar Kensei justify the $120 bump in price over the standard model?
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Incorporating the Apple H2 chip, Bluetooth, spatial audio, wireless charging and more, the Beats Powerbeats Pro 2 wireless earbuds offer a lot for just...
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Is FiiO’s lineup of Dongle DACs starting to cannibalize itself? The addition of aptX HD and LDAC support makes this more of a bargain.
Priced at $234.99, the Cleer ARC 3 Gaming Edition comes with a USB-C dongle for low latency wireless gaming.
