Dongle DACs
FiiO’s BT11 Portable Bluetooth Transmitter Might Level the Playing Field For iPhone Users
This $44 USB-C adapter adds hi-res Bluetooth wireless connectivity to devices such as iPhone that don’t support aptX Lossless or LDAC.
FiiO BT11 Portable Hi-res Bluetooth Transmitter in black and silver
Christmas and Chanukah are coming early this year for iPhone users who feel shortchanged when it comes to streaming hi-res audio (let alone 16-bit/44.1kHz). Android users have been spoiled for years — but all of that might be coming to an end thanks to a new dongle from FiiO that promises a lot. The new FiiO BT11 Portable Bluetooth Transmitter could change your hi-res streaming experience in a very meaningful way if you don’t mind having it as part of your smartphone on a more permanent basis.
The BT11 supports a wide range of codecs, including aptX Lossless, LDAC, aptX Adaptive, aptX HD, aptX LL and more — allowing users to enjoy up to 24-Bit 96kHz wireless audio as offered by the major streaming services.
FiiO BT11 Portable Hi-res Bluetooth Transmitter in silver connected to phone
Available in black and silver finishes, this small device simply plugs into the your iPhone’s USB Type-C port and enables high-quality connectivity to wireless headphones and speakers.
The BT11 supports simultaneously connecting to two receiving devices. Equipped with Qualcomm’s flagship Bluetooth chip — the QCC5181 — it features a quad-core processor architecture and two 240MHz Qualcomm Kalimba audio DSPs.
The BT11 also supports Snapdragon Sound, which delivers an immersive lossless audio experience with compatible devices.
Thanks to its support for the latest Bluetooth 5.4 version, the BT11 provides a more stable connection, longer transmission ranges, and overall system performance improvements — all at lower power consumption.
Connect the BT11 to the FiiO Control App for iOS and Android and easily control the device and access functions such as simultaneous pairing to two devices.
The BT11 will also be upgraded via over-the-air (OTA) updates, with scheduled updates including: addition of the LC3 Codec, volume adjustment, indicator light control, channel balance adjustment, and pairing lists.
The color RGB indicator light on the BT11 clearly displays the working status of the device, as well as the current Bluetooth codec being used.
Codec Color State
RGB Light Indicator
SBCBlue pulsing light
aptX/aptX Low LatencyPurple pulsing light
aptX HDYellow pulsing light
LDACWhite pulsing light
aptX Adaptive/aptX LosslessGreen pulsing light
PairingBlue flashing light
Waiting to reconnectRed and blue lights flashing
FiiO BT11 Portable Hi-res Bluetooth Transmitter in silver connected to laptop
Specifications
Bluetooth Version5.4
Bluetooth ChipsetQualcomm QCC5181
Bluetooth Codec SupportSBC, aptX, aptX Low Latency, aptX HD, aptX Adaptive, aptX Lossless, LDAC
Dimensions28mm x 21mm x 9mm
Weight3g
In the box1 x BT11
1 x USB Type-A to USB Type-C Adaptor
1 x Quick Start Guide
1 x Warranty Card
Available FinishesBlack or Silver
FiiO BT11 Portable Hi-res Bluetooth Transmitter what's in the box
Initial Impressions
We’ve been waiting for something like the FiiO BT11 for awhile and anything that improves the wireless streaming experience for the tens of millions of consumers in North America who use wireless earbuds or wireless headphones as their primary listening device — is a huge step forward.
With so many new wireless earbuds and headphones flooding the market, we’ve reached the point where there are options that support hi-res codecs and for those of us who listen to TIDAL, Qobuz, Amazon Music HD, or Apple Music (sorry Spotify) — and own wireless headphones that can offer hi-res playback — this is something that makes a lot of sense. Most certainly for the price.
Will mainstream users be able to tell the difference? We will let you know when our review sample arrives and we have an opportunity to pass it around.
Price & Availability
The FiiO BT11 will be available from Oct 8th, priced $44 USD (£42 / €49).
For more information: fiio.com/bt11
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
March has been a busy month for new headphone introductions, including the Focal Bathys MG and Meze Audio POET.
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PS10 DAP might replace your streamer.
At $299, the Bose Ultra Open Earbuds offer excellent situational awareness, support for Snapdragon Sound, and one surprising feature.
Universal IEMs with 13 drivers? FiiO's FX17 integrates electrostatic and dynamic drivers, and balanced armatures in a titanium ear shell.
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
The FiiO FT7 Open-back Planar Magnetic Headphones will debut at the Bristol Hi-Fi Show and CanJam NYC this weekend.
