Fezz Audio Equinox Vacuum Tube DAC Licenses Lampizator Technology
Starting at $2,995, the Fezz Audio Equinox Vacuum Tube DAC is the most affordable D/A converter with Lampizator technology.
Fezz Audio Equinox Vacuum Tube DAC in Sunlight Finish Front View Angle
The new Fezz Audio Equinox Vacuum Tube DAC ($2,995) is the only Lampizator licensed vacuum tube D/A converter designed by Łukasz Fikus. It is also the most affordable D/A converter available with the Lampizator logo.
Equinox is based on the PCM1794 chipsets and incorporates a single 12AU7 vacuum tube. Fezz/Toroidy engineers designed a dedicated, supreme-class toroidal power transformer for use as Equinox’s power supply.
Fezz Audio Inside Factory
The Equinox provides 2 Toslink, 1 coaxial 1 USB digital signal input, and one set of RCA outputs. Via the easily accessible tube housing, located under the sliding glass door on the top panel, Equinox users can swap in different 12AU7 tubes per their preference.
A step-up model called the Fezz Audio Equinox Prestige ($3,995) includes two 12AU7 Vacuum Tubes and adds balanced audio outputs.
Comparison
fexzz-audio-equinox-equinox-presitge-900
Equinox Equinox Prestige
Price$2,995$3,995
Product TypeD/A converter empowered by LampizatorBalanced D/A converter empowered by Lampizator
ModelEquinox EVO D/A converter empowered by LampizatorEquinox Prestige EVO D/A converter empowered by Lampizator
Tube Type1 x ECC82/12AU72 x ECC82/12AU7
Digital InputsUSB type B, 2 x S/PDIF, CoaxialUSB type B, 2 x S/PDIF, Coaxial
Output1 x RCA1 x RCA, 1 x XLR
OP AMPBurr-Brown PCM 1794Burr-Brown PCM 1794
S/PDIF ReceiverAsahi Kasei AKM4118Asahi Kasei AKM4118
PCM Sampling Rates32kHz to 192kHz, 16 to 24-bit, USB connection: up to 384kHz and 32-bit 32kHz to 192kHz, 16 to 24-bit, USB connection: up to 384kHz and 32-bit
USB CompatibilityWindows 7, 8, 8.1, 10, 11, Mac OS X 10.6 or later, Android 12 or later.Windows 7, 8, 8.1, 10, 11, Mac OS X 10.6 or later, Android 12 or later.
THD (Total Harmonic Distortion)< 0,05%< 0,05%
Power Consumption9 W25 W
Dimensions355 x 380 x 95mm
(14 x 15 x 3.7-inches)
355 x 380 x 100mm
(14 x 15 x 4-inches)
Net Weight8 kg (17.6 lbs)8 kg (17.6 lbs)
In The BoxEquinox D/A converter
Power cord
User manual
Equinox Prestige D/A converter
Power cord
User manual
Fezz Audio Equinox Rear
Fezz Audio Equinox
Fezz Audio Equinox Prestige Rear
The Bottom Line
At the same time we are seeing prices of dedicated standalone DACs coming to market at affordable prices such as the $299 iFi ZEN Blue3 and $229 ZENDAC 3, there still seem to be some high-priced DACs beckoning the wallets of audiophiles. Examples include the recently released $95,000 MSB Cascade, $3,098 Holo Audio Spring3 KTE, the $1,600 Gungnir 2, and now the Fezz Audio Equinox ($2,995) and Equinox Prestige ($3,995).
Fezz Audio has become an important part of the Polish high-end audio scene and there is no question that they offer excellent components that are starting to gain some traction with North American audiophiles.
The collaboration with Lampizator gives us some confidence that this DAC might be well worth auditioning for those who want something bespoke and rather “analog” sounding. And that’s meant to be a compliment.
Fezz Audio Equinox Prestige 12AU7 Vacuum Tubes
12AU7 Vacuum Tubes
Price & Availability
The Fezz Audio Equinox ($2,995) and Equinox Prestige ($3,995) DACs are currently available in the U.S. in black ice (black) and sunlight (champagne) finishes. Check for a dealer near you
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Hi-Fi Components
High-end manufacturers in Asia and Europe were caught off-guard by the unexpectedly high tariffs levied yesterday but one distributor was already ready.
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
At $1,999, the Technics HA-507 is a pure analog headphone amplifier and preamplifier with a balanced/dual mono configuration.
Borrowing design concepts from TEAC’s top-of-the-line 700 Series, the standout feature of the UD-507 is TEAC’s new proprietary "TRDD5" (TEAC Reference Discrete DAC) designed...
iFi claims that the ZEN Blue 3 is the world's first lossless audio receiver and transmitter with speeds up to 1200kpbs.
North American audiophiles can now experience Leema Acoustics’ Welsh-made hi-fi components.
Digital Music Systems
When cost is no object, the ultimate in digital music playback has arrived from dCS, but you will need to bring your own amps...
