Feliks Audio’s Envy Meisterwerk Tube Headphone Amp Will Illuminate Your Favorite Music
Priced from $10,000, the Feliks Audio Envy Meisterwerk headphone amplifier features all analog circuitry with 300B vacuum tubes.
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Front Angle in Ebony finish
Poland-based Feliks Audio specializes in high-end vacuum tube audio products including a line of rather unique headphone amplifiers. Their latest entry into the headphone amplifier category is the Limited Edition Envy Meisterwerk. This unit represents another iteration of the previously released Envy, with an emphasis on both style and performance.
The Tubes
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Front View in Zebrano Finish
At its core, the Envy Meisterwerk incorporates Western Electric 300B Output Tubes. As the inventor of vacuum tube technology, Western Electric pioneered vacuum tube technology in the 1900s. The 300B was introduced way back in 1938 and has stood the test of time for its audio quality to this day with a 40,000-hour expected life.
Whilst there are a number of other 300B output tubes available on the market from vendors in China, Russia (which are still banned because of the ongoing conflict in Ukraine), and elsewhere — the Western Electric 300B is still very popular and extremely expensive.
Precision Engineering
To support the 300B’s, the Envy Meisterwerk includes optimized circuitry and selected supporting driver tubes. This maximizes the performance of the 300B tubes for clarity and depth. Also, in keeping up with modern eco-consciousness, the Envy Meisterwerk is built from responsibly sourced materials.
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Vacuum Tubes
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Rear Connections
Input Options
The Envy also providess two sets of analog RCA and XLR inputs for wired sources. Although the Envy is all analog and has no wireless functionality, you can connect it to digital sources provided they have built-in DAC and analog audio outputs. You can also connect a turntable that has a built-in phono preamp or place a phono preamp between the turntable and Envy’s inputs.
Preamp Outputs
In addition to being a headphone amplifier, the Envy Meisterwerk includes both RCA and XLR preamp outputs for connection to external powered speakers, an amplifier, or an audio system for connection to speakers.
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Rear View
Envy Meisterwerk (Zebrano finish) with headphones.
Specifications
Let’s dig a little deeper into what makes the Envy Masterwerk tick with regard to the actual needs and desires of headphone listeners.
Price€9,235 (Zebrano finish)
€12,596 (Ebony finish)
Amplifier TypeClass A Single-ended transformer coupled
Power Tubes2 x Western Electric 300B
Driver Tubes2 x PsVane CV-181 mk2 (6SN7)
Audio Inputs2x unbalanced RCA inputs (IN1, IN2)
1x balanced XLR input (IN3)
Input Sensitivity1V RMS
Input ImpedanceFor IN1 i IN2 (RCA) 100kΩ
For IN3 (XLR) 10kΩ
Preamp Outputs1x pair RCA
1x pair XLR
Preamp Outputs Maximum Voltage 5V (RMS) at an output impedance of 600Ω and THD<0,5%
Impedance Selector OptionsLO – up to 60Ω
MID – up to 300Ω
HI – up to 600Ω–mnh
Amplifier ImpedanceLO at 32Ω load is 3.8Ω
MID at 100Ω load is 8.8Ω
HI at 600Ω is 20Ω
Amplifier Power OutputMeasured at MID impedance setting at load of 16Ω is 5W with THD ⩽1% (maximum 8W at THD >5%)
Frequency Response8Hz-100kHz ±3dB
18Hz-40kHz ±1dB
Headphone Outputs1 x 6.3mm
1 x  XLR
AC voltage 50/60Hz230V version (±5%)
115V version (±5%)
Power Consumption110VA
Dimensions (LxWxH)35x33x18.5cm – without tubes
35x33x24.5cm – with tubes
Weight15.1 kg
Included Accessories2 x  300B Power Tubes
2 x CV-181(6SN7) Driver Tubes
AC cord
User Manual
Warranty Card
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier in Zebrano Front View with Headphones
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone (Zebrano)
Bottom Line
We first encountered one of the previous incarnations of the Feliks Audio Envy Headphone Amp at T.H.E. Show 2023. At $8,000 (US), the Envy provided impressive performance with a variety of high-end headphones.
The Feliks Limited Edition Meisterwerk version takes engineering up a notch with a $1,200 or $4,500 jump in price depending on the selected finish.
What makes the Limited Edition Meisterwerk version different is that although previous Envy models used 300B power tubes from various manufacturers, the Meisterwerk is the first-ever Feliks amp to use the original Western Electric 300B tubes. To use these tubes, Feliks also modified the internal circuitry of the amp to match their power, but the Meisterwerk maintains the original sound character and design of previous Envy’s.
Whether the implemented upgrades justify the big jump in price is the question.
Feliks Audio Envy Meisterwerk Vacuum Tube Headphone Amplifier Ebony
Feliks Audio Envy Meisterwerk (Ebony finish)
Price & Availability
The Feliks Audio Envy Meisterwerk is available exclusively from headphone.shop for €9,235 (Zebrano finish) or €12,596 (Ebony finish). Contact headphone.shop for US pricing.
The previous Envy and Envy Performance models start at $8,000 and are also available at Headphones.com and Audio46.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
At only $64.99 each, the Apos Ray 6SN7 Select vacuum tubes may deliver the dynamics and authentic sound you've been seeking.
At $9,999, the Unison Research Simply 845 Integrated Tube Amplifier makes a strong case to be the last amp you'll ever buy.
With 100V on the plate, Schitt claims its Vali 3 tube headphone amp and preamp beats everything they've tested up to $2,799, for only...
What will we be reviewing in 2024? Some early thoughts on the Unison Research Simply 845 Integrated Amplifier.
Whilst not inexpensive, the Apos Ray 12AU7 Vacuum Tubes offer excellent sound quality, superior packaging and matching, and a 90-day warranty.
One of the strangest looking loudspeakers at T.H.E. Show also produced some of the best sound driven by the Takatsuki TA-S01 300B Power Amplifier....
Would you spend $7,995 on a headphone amplifier? The Feliks Audio Envy did not disappoint with some of the best headphones in the world.
From beyond the Iron Curtain? A new generation of Polish high-end audio manufacturers are creating some incredible new amplifiers. The Fezz Audio Evolution Series...
