FAVI Boomerang Wireless Audio Dock
FAVI Boomerang with iPhone
FAVI Entertainment just introduced its crescent-shaped Boomerang Wireless Audio Dock, an on-the-go home-theater for your mobile device or tablet with tap-to-pair NFC Technology. It rests on the outside edges of your mobile device allowing you to enhance your audio experience anywhere, anytime.
The Boomerang Wireless Audio Dock uses the latest version of Bluetooth + NFC (Near Field Communication) technology. This allows users to easily tap their Bluetooth enabled device to the Boomerang to pair with it. The Boomerang’s unique shape makes it convenient to carry, fitting comfortable around a user’s neck while not in use.
“Whether you’re watching a movie or chatting over Skype, you shouldn’t be limited to the stock audio of your device” said Jeremy Yakel, President of FAVI Entertainment, “The Boomerang allows you to get stereo style sound on your iPad, iPhone or Android device with a simple tap.”
FAVI Boomerang with iPad
Other key features include:
  • NFC Technology allows you to pair your device with a quick tap, operating up to 33 feet away
  • Expansion Sleeve Design allows you to easily adjust the viewing angle and accommodate for various sizes
  • Built-in Speakerphone allows you to listen, talk and answer phone calls via the speaker
  • 2 x 6W Stereo Sound in the Boomerang from integrated bass boosts
  • 2 x 4W Stereo Sound in the Boomerang Mini from integrated bass boosts
  • 10 Hours of Battery Life from its built-in lithium ion battery
  • Colorful Options available in white, black, red, yellow, purple and pink
Price and Availability
The Boomerang will be available for $79.99 and the Boomerang Mini will be available for $59.99 beginning in mid-December 2013.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
