Fatman Carbon Trinity iPod Speaker Dock
Fatman by TL Audio announced the Carbon Trinity iPod/iPhone-compatible amplifier dock is now available with or without speakers.
The Carbon Trinity is the third generation machine in the Fatman 'all-in-black and all-in-one' line. This hybrid vacuum tube amplifier features and on-board iPod/iPhone dock, and is available with our without bespoke speakers. Another Fatman model to welcome USB to its connectivity list, the Trinity also adds the option to beef the bass via its sub-woofer output. The full-function remote control enables the user to stay comfortably seated while drilling through Apple portable player menus.
Specifications
  • Source Inputs: 1xRCA Pair, USB, 1×3.5mm
  • Aux Power Output: 25Wx2
  • Frequency Response: 20Hz – 20KHz (±1.5Db)
  • Distortion: ≤0.5%
  • Signal-To-Noise Ratio: ≥86Db
  • Input Sensitivity: 200mV
  • Input Impedance: 100KΩ
  • Output Impedance: 4Ω, 8Ω
  • Sub Out: Yes
  • Tubes Used: 6E2 x 1, 6N2 x 2
  • Power Supply: AC100~120V/50~60Hz, AC220~240V/50~60Hz
  • Dimensions: Amp (WxHxD) 374x205x155mm
  • Amp Weight: 5.8KGs
  • Amp Type: Hybrid
Pricing
  • Fatman Carbon Trinity: £400
  • Fatman Carbon Trinity with speakers: £500
About TL Audio
TL Audio began manufacturing professional audio valve products in 1993, almost single handedly kick-starting the valve revolution. Respected by producers, sound engineers, TL Audio valve units are used in studios the world over. From the outset its design philosophy has been to utilise the best qualities of both tube and solid state circuitry to produce a superb combination of sound and performance. And this mantra has been carried through to its range of Fatman hi-fi products.
Launched in 2006 Fatman quickly established its reputation for producing some of the best performing audio systems for use with Apple's iPod, or indeed any portable or fixed media device. All iTube amplifiers have additional inputs for CD etc., making them fully comprehensive audio systems for all audio sources.
But why valves? Well, as professional recording artists and producers discovered, digital with all its acknowledged advantages can sound a little cold and harsh, lacking in 'warmth'. That's where valves come in. Correctly and sympathetically inserted into the signal path, the presence of valves enhances signal quality. The skill in valve design is in knowing where to place the valves and how to combine them with state-of-the art solid state circuitry in order to achieve maximum sonic benefit. With over a decade's experience in professional audio, the people behind Fatman have this skill. And then some.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
