FABRIQ Chorus is Alexa Multi-room Wireless Speaker
FABRIQ Chorus Wireless Smart Speaker in quartz
FABRIQ just introduced a wireless smart speaker called Chorus that bundles Amazon Alexa inside. The $100 speaker is multi-room capable and responds to voice commands just like the Amazon Echo.
The FABRIQ Chorus is the bigger brother to FABRIQ’s smaller Alexa-enabled speaker called Riff for $50. Other than size, the main difference is that Riff is touch activated to enable Alexa and Chorus responds to the wake word “Alexa”.  On either, you can use your voice to ask Alexa to play music, check the weather, place calls and more.
With 8 watts of power, two drivers and a passive radiator, Chorus is powerful enough as a standalone speaker, but even better when pair more. Up to ten FABRIQ speakers can be used together. Built-in Bluetooth and Wi-Fi allow you to stream music from most major services and have access to your music on the go.
“We were able to deliver tremendous value when we launched the touch activated Riff last year, but knew we were leaving a large portion of the market untouched without a voice activated unit,” said Jordon Sansom, Director of Marketing, FABRIQ. “We were building Chorus in tandem with Riff, but needed time to make sure the far field voice control technology worked in conjunction with Chorus’s speaker power. During this time, we were able to observe consumers reception to products on the market which helped to solidify what features we wanted to include in our all-in-one Alexa solution at the sub $100 price point.”
Specifications:
  • Audio: Two 2” precision active drivers and a 2” passive radiator combined with 8-watts of power
  • Battery: Up to 6 hours, 7.4V (2200mAh Capacity)
  • Wi-Fi and Bluetooth connectivity
  • Voice-activated Alexa through far field technology
  • Compatible with both iOS and Android
  • Connects up to ten FABRIQ speakers
  • Dimensions: 3.15” x 3.15” x 6.3”
  • Weight: 540g
“There are several smart speakers currently on the market but each one seems to compromise an important feature. With Chorus, we set out to fulfill the consumer’s full wish list – excellent audio, the ability to link with other smart speakers, the ability to play music from major streaming services, voice control and affordability – all without breaking the bank,” said Sansom. “We have seen the profound impact voice has had on the adoption of smart home technology and we will continue to advance our technology as we further grow the FABRIQ brand.”
Price and Availability
The Fabriq Chorus is available immediately on Target.com, Amazon.com and thefabriq.com for $99.99 and will be available September 24, 2017 in Target stores nationwide.
Colors Options
At launch, Chorus will be available in four different patterns so consumers can find a design that matches their style. Target stores will carry two exclusive patterns in-store for guests: Duke of Earl and Static. Two additional patterns, Quartz (white) and Midnight Blue, are available on Target.com and Amazon.com. Additional seasonal patterns will be available in coming months.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
