Eversolo’s New Flagship DMP-A10 Is Much More Than a Music Streamer
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
Eversolo DMP-A10 Music Streamer Front Angle
Eversolo, makers of digital audio playback devices, introduced its new flagship Music Streamer, the DMP-A10 at the Paris Audio Video Show on October 25, 2024. This high-end network streamer has upgraded DAC and Preamp sections and can function as a music server with slots for optional SSD storage. In addition, the DMP-A10 incorporates visually pleasing design with a 6.5’’ high-definition touchscreen that can also display album art and system status, along with a unique 1.28’’ circular display on the volume knob.
From Eversolo’s CMO: Our R&D team is dynamic and experienced, developing all hardware and software in-house to ensure superior sound quality and user experience.”
On The Inside
On the inside, the DMP-A10 incorporates an ESS9039 Pro flagship DAC and dual linear power supplies that reduce noise and distortion, supporting a better listening experience.
Eversolo DMP-A10 Music Streamer Inside
A dual OCXO clock system keeps A10’s audio oscillators (operating at 45.1584MHz and 49.152MHz) at a consistent temperature, which eliminates temperature-affected frequency fluctuations. This results in low-phase noise and jitter levels below 50 fs.
A high-speed electrical isolation system separates noise and interference between circuit boards. This minimizes audio circuit disruption during signal transmission of the system circuit.
Streaming
Eversolo DMP-A10 Music Streamer Angle Left
The DMP-A10 provides access to native music services via API, including TIDAL, Qobuz, Amazon Music, TuneIn, Radio Paradise, and more, and supports cross-platform song search. It also functions as a home streaming hub, supporting TIDAL Connect, Squeeze Connect, DLNA, and UpnP protocols.  The DMP-A10 is also Roon Ready.
Physical Connectivity
Eversolo DMP-A10 Music Streamer Rear Angle
The DMP-A10 provides abundant physical connections two coaxial, two optical, HDMI ARC, and an isolated USB B input for connecting PCs and mobile devices. Plus, it is also a digital transport via isolated USB ports, and optical, or coaxial outputs.
The isolated USB audio input/output port is designed to eliminate interference from high-noise power sources and address grounding loop issues. This means that USB signals maintain quality with minimal noise and distortion.
High-performance fully balanced analog circuitry supports XLR/RCA analog inputs and outputs, allowing direct connection to powered speakers or amplifiers. With +10dB analog gain and R2R analog volume control, it delivers ultra-low noise and distortion, significantly enhancing dynamic range and overall sound integrity.
Eversolo DMP-A10 Music Streamer Rear Angle Close
Digital to Digital Converter (DDC)
In addition to a built-in DAC, the DMP-A10 provides additional support from its Digital-to-Digital Converter (DDC). Digital signals can be output as SPDIF or analog after EQ adjustments, while analog inputs can be captured via high-spec ADC (up to 192kHz) and processed for output as either SPDIF or analog.
Subwoofer Connections
Users can also connect the DMP-A10 to one or two subwoofers or disable the subwoofer output feature if so desired.  The DMP-A10 can switch between MIXER and STEREO modes, as well as adjust subwoofer gain, crossover frequency, and delay.
Pro Tip: The subwoofer function is only effective for PCM signals below 192kHz.
Other Supporting Features
Eversolo DMP-A10 Music Streamer Circular Display on Volume Knob
The touchscreen user interface is intuitive, while the dedicated control app provides additional wireless control as does the provided remote control.
To aid in setup, the DMP-A10 provides Digital Room Correction technology that adjusts frequency response based on room characteristics, eliminating unnecessary acoustics issues, and providing more accurate sound reproduction.
Pro Tip: To use digital room correction, you need to connect the DMP-A10 to a set of powered speakers or an audio system with speakers.
The DMP-A10 provides flexible music management capabilities. It supports playback and importing of music files stored on NAS devices or network drives within the local area network.
The DMP-A10 also includes dual SSD slots that support up to 2 x 4TB of storage.
Pro Tip: With the added capability to connect an external USB CD-ROM drive, the DMP-A10 can play and rip CDs, allowing users to consolidate their music collection for a gapless listening experience.
Specifications
Price$3,680
ModelEversolo DMP-A10
Display6.5-inch LD Touchscreen
Internal Memory4GDDR4 + 64GeMMC
DACES9039 PRO
Audio ProcessorXMOS XU316
Op-Amp ChipOPA1612
StreamingSqueezelite, DLNA,  Tidal Connect, and more
Roon ReadyRoon Ready
Music ServicesTidal, Qobuz, Hi-res audio, Amazon Music, Deezer, Radio Paradise, TuneIn Radio, Apple Music, KKBOX, UPnP
BluetoothVer 5.0, SBC/AAC
Isolation USB-B Audio InputSupports Windows (10/11), Android, iOS, Supports up to stereo DSD512, OCM 768KHz/32Bit
Optical/Coaxial Audio InputsSupport up to stereo PCM 192kHZ 24bit Dop 64
XLR Audio Output CharacteristicsOutput Level: 4.2  V
Frequency Response: 20Hz to 20kHz +/- 0.15dB
Dynamic Range: > 130dB
THD+N: <0.000078% (-122dB) @  No-wt
Crosstalk: >123dB
RCA Audio Output CharacteristicsOutput Level: 2.1  V
Dynamic Range: > 129dB
THD+N: <0.00009% (-122dB) @  No-wt
Crosstalk: >122dB
USB-A PortUSB ver 3 x 2
Isolation USB Audio OutputSupport up to stereo DSD512, PCM up to 768KHz 32Bit
Playback and DAC DecodingSupports up to stereo DSD512, PCM
Digital Optical/Coaxial OutputSupport up to Stereo PCM 192KHz 24Bit Dop64
When routed through the DSP module, it supports a max of stereo PCM 96kHz
Analog Audio OutputPreamp Audio Output – XLR (Balanced) + RCA (Unbalanced)
Analog Preamp Audio OutputXLR (Balanced) x 1 + RCA x 2 (Unbalanced)
Supports ADC Acquisition with support up to 192kHz
Subwoofer Out2, Supports Stereo Mode/Mixer Mode
SSD (Optional)Support M.2 NVME  3.0  2280 protocol, up to 4TB x 2
SFP Fiber InternetSupports external single-mode single-fiber and single-mode dual-fiber SFP Modules (Modules require separate purchase)
EthernetRF-45/10/100/1000Mbps
WiFiWiFi 2.4Gb + 5G Dual Band
Control MethodMobile App, Touchscreen Control, IR – Bluetooth Remote Control
PSUAc 110-240V 50/60Hz
Rated Power30 Watts
Power Supply 2 x High Quality, Low Noise Linear Power Supply
Dimensions (WLH)430 x 310 x 117 mm
Packing List (Included Accessories)1 x Power Cable
1 x Trigger Cable
1 x Remote Control
 3 x Antennas
 1 x User Manual
Eversolo DMP-A10 App
The Bottom Line
With the Eversolo DMP-A10, things are getting more crowded in the premium Music Streamer product category. At $3,680 Eversolo’s new flagship streamer has a lot to prove since it’s nearly double the price of the company’s previous top streamer, the DMP-A8 ($1980 at Amazon).
In addition to incorporating streaming and extensive physical connectivity, the DMP-A10 also offers room correction, both a 6.5-inch touch screen (including a choice of four VU meter designs) and a display screen on its volume control. In addition, the DMP-A10 has lots of storage capacity and the availability to play and rip CDs when connected to a CD-ROM drive. However, one thing it’s lacking is a built-in headphone amplifier to easily listen with connected headphones.
That being said when you add everything up the DMP-A10 might just be the Swiss Army Knife of streamers. At $3,680 you have to dig deeper into your wallet to afford one, but not as deep as you would if you were purchasing the $12,000 Marantz Link 10n. But then again, you can save a lot of money if you opt for WiiM Ultra for $329 which offers more than you would think with such a low price tag.
Price & Availability
The Eversolo DMP-A10 Flagship Streamer/DAC/Preamp is available now for $3,680.
For more information: eversolo.com
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
