Eton Mobius Solar Charger / Case for iPhone 4
Eton introduced the Mobius rechargeable battery case with solar panel. Designed for the iPhone 4, the rechargeable battery case features a high-efficiency monocrystal solar panel that needs only one hour in the sun to provide an additional 25 minutes of talk time.
Differentiating itself from solar-charging solutions on the market today, Mobius features a quick charge time and the ability to store charge until you need it. The high-efficiency monocrystal solar panel re-charges the 1800 mAh Rechargeable lithium ion battery pack on the back of the case. Only one hour of solar charging provides an additional 25 minutes of talk time, 20 minutes of internet use, 35 minutes of video playback and more than two hours of audio playback. Mobius can also be charged via the included Micro-USB cable and will sync with iTunes for maximum convenience. Once the battery has been re-charged, the user is in control as to when the extra battery power is used. Mobius features a standby switch to turn off direct power transfer to the iPhone 4, allowing the case to charge and store energy in its own battery — only using the power when you need it.
Eton Mobius Charge Times
The durable and ergonomic battery case has both a battery charge and solar charge indicator, so the user always knows the power status of the Mobius. Weighing only 3.4 ounces, Mobius also features a USB connection to charge the battery via computer, as well as the unique and proprietary snap fit design protects the glass on the back of the device.
Price and Availability
The Eton Mobius is available now for $80 at Amazon.com.
1 Comment
1 Comment
  1. Bill
    October 10, 2012 at 3:13 am
    I recently contact Eton regarding the long solar recharge time. In response according to the Eton Corp tech support, the solar charging information (1 hour of solar charge) on the packaging is wrong. The correct information is: “Solar charging the mobius for one hour, in direct sunlight, allows the iphone 4 or 4s to make one or two, short emergency calls. It takes about 36 hours of direct sunlight to full charge it via solar power. If there is no direct sunlight, it will take longer. Solar charging is extremely slow. “
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
