Accessories
Eton BoostSolar Mobile Charging Solution
Eton BoostSolar
Eton announced BoostSolar, a solar-powered backup battery pack, allowing you to re-charge smartphones and tablets on the go. A single solar panel, on top, provides the power to recharge its internal lithium battery (5000 mAh), which then provides the stored power to recharge a handheld device twice on a single charge.
With the ability to fully charge in ten hours via the sun, or in seven hours by way of the Micro-USB DC input, BoostSolar includes a standard USB port for charging any of your mobile devices. BoostSolar also boasts the ability to charge multiple backup batteries in succession – simply snap on a removable battery pack and allow it to charge, and then replace it immediately with another to gain unlimited backup power. With the press of a button, LED charge indicators provide the user with the amount of battery charge left in their device.
In addition to being durable and IPX-4-rated splash-proof, BoostSolar also features fastener holes that enable it to be easily attached to a backpack for maximum portability and to charge while you’re on the go.
“With its ability to charge handheld devices and their backup batteries, BoostSolar is the perfect solution when enjoying your outdoor adventures to ensure you always have power to make a call or send an important text,” said Esmail Hozour, CEO of Eton Corporation.
[youtube id=”T1ncrBbcBh8″ width=”610″ height=”373″]
Price and Availability
The Eton BoostSolar will be available Q2 2013 for $99.99. BoostSolar Battery Packs will also be available for purchase separately.
Eton BoostSolar - topEton BoostSolar - back
Linear Tube Audio Aero+ DAC Angle
2026 Adam Audio H715 Reference Open-back Studio Headphones 2026 Adam Audio H715 Reference Open-back Studio Headphones
AT $699, ADAM Audio's flagship H715 Reference headphones, combine Sonnox calibration, balanced Hi-Fi mode, and studio monitoring in one design.
2026 Audio-Technica ATH-AWX7000 Headphones 2026 Audio-Technica ATH-AWX7000 Headphones
Audio-Technica's $3,800 ATH-AWX7000 combines Japanese Cypress wood, luxury craftsmanship, and new 58mm drivers. Can it challenge the best closed-back headphones?
