Loudspeakers
Ethereal Introduces Deluxe 6.5 2-Way Ceiling Speaker
Ethereal Home Theater Accessories adds the SP601 Deluxe 6.5″ 2-Way Ceiling Speaker to its family of high-performance architectural speakers. Engineered for excellent audio reproduction in settings in which freestanding speakers may be impractical or undesirable, the SP601 features a pivoting 1/2″ soft dome tweeter that directs high frequencies to the optimum area for creation of the best possible sound stage in any home theater environment.
High power-handling capabilities permit use of the SP601 with home theater receivers utilizing multi-channel amplifiers for delivering the larger-than-life sound produced in today’s movies.
As with Ethereal’s entire architectural speaker line, the powerful SP601 has a low-profile frame, tight mesh paintable grille and the “Quick-Loc” mounting system for a firm, secure installation that greatly reduces speaker vibration. Affordable pricing also makes it easy to use the SP601 to experience richly detailed music throughout the home.
Specifications:
  • 1/2 ” soft dome neodymium tweeter with pivoting tweeter.
  • 6dB/octave crossover
  • 8 ohms; 80 watts
  • 6 1/2” woofer with polypropylene cone and butyl rubber surround
  • Heavy-duty mounting clips and spring clip terminals
Based in Holly Hill, FL, with offices in Long Beach, CA, Metra (www.metraonline.com) is a leader in the auto sound industry as parent company of such consumer and professional installation brands as Axxess, Install Bay/FishMan, Raptor, Silencer and Tsunami, as well as the Ethereal (www,etherealhometheater.com) brand of home audio/video interconnects.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
