Based out of Estonia, Estelon is expanding their entry-level A-Series loudspeaker lineup with their smallest and least expensive models yet. They join the AURA floorstanding speakers (released in 2023 for €19,990), and include the AURELIA, AURELIA Centre, and AURUS Subwoofer, which can be used together in a high-end audio or home theater setup.
From Estelon: “The AURA is part of the A-Series. We launched this model a couple of years ago, and so due to its success, we expanded the line.”
The new A-Series speaker additions will be officially introduced at the High End Munich 2025, marking a significant moment for the brand. This event, which coincides with Estelon’s 15th anniversary, promises to be a landmark occasion, spotlighting these groundbreaking speakers to the global audio community.
AURELIA
The AURELIA is a 2-way passive bookshelf/standmount speaker with a sealed box design, aimed at delivering controlled bass and a balanced soundstage. It uses two 132 mm (5”) Egyptian Papyrus fibre-filled paper cone mid-range drivers from SB Acoustics and a 25 mm (1”) textile dome tweeter from Scan-Speak. The combination is designed to offer clear, detailed sound suitable for a range of listening environments.
The AURELIA’s cabinet is made from a thermoformed mineral-filled composite, chosen to reduce resonance and standing waves. It’s intended for small to medium-sized rooms, home offices, and TV setups, with a form factor that fits into a variety of living spaces.
AURELIA Centre
Built with the same design principles as the AURELIA, the AURELIA Centre is designed for home theatre use. It aims to deliver consistent tonal balance and clear imaging for center channel content, including dialogue and front-stage sound effects.
Comparison
AURELIA (2025) | AURELIA Centre (2025) | AURA (2023) | |
MSRP | €14,900/pair | €7,500/each | €19,900/pair |
Speaker Type | 2-way passive speaker, sealed box | 2-way passive speaker, sealed box | 3-way passive speaker, sealed box |
Size | Bookshelf | Bookshelf | Floorstanding |
Tweeter | 1 x 25 mm (1”) textile dome tweeter from Scan-Speak | 1 x 25 mm (1”) textile dome tweeter from Scan-Speak | 1 x 26mm (1-inch) Scan-Speak “Illuminator” Textile Dome tweeter |
Midrange | 2 x 132 mm (5”) mid-range drivers from SB Acoustics | 2 x 132 mm (5”) mid-range drivers from SB Acoustics | 2 x 130mm (5-inch) mid-woofer made by Satori |
Woofer | – | – | 1 x (250mm) 10-inch down-firing woofer |
Frequency Response | 70 – 30,000 Hz | 70 – 30,000 Hz | 35 – 25,000 Hz |
Power Rating | 80 Watts | 80 Watts | 200 Watts |
Nominal Impedance | 4 Ω (min 3.7 Ω at 170 Hz) | 4 Ω (min 3.7 Ω at 170 Hz) | 4 Ω (min 2 Ω at 58 Hz) |
Sensitivity | 87 dB/2.83 V | 87 dB/2.83 V | 90 dB/2.83 V |
Min Amplifier Power | 30 Watts | 30 Watts | 30 Watts |
Internal Cabling | Kubala-Sosna | Kubala-Sosna | Kubala-Sosna |
Cabinet Material | Thermoformed mineral-filled composite | Thermoformed mineral-filled composite | Marble-based composite |
Finish Options | White Black Gloss Horizon Blue Starlight Amber Elegance Iron Grey | White Black Gloss Horizon Blue Starlight Amber Elegance Iron Grey | White Black Gloss Horizon Blue Starlight Amber Elegance Iron Grey |
Dimensions (HWD) – Without Stand | 550 x 290 x 210 mm 21.6 x 11.4 x 8.3 inches | 237 x 520 x 195 mm 9.3 x 20.4 x 7.6 inches | 1366 x 384 x 367 mm 53.7 x 15.1 x 14.4 inches |
Dimensions (HWD) – With Stand | 1155 x 305 x 295 mm 45.4 x 12 x 22.6 inches | – | – |
Weight (per speaker) | 9.5 kg (20.9 lbs) | 10 kg (22 lbs) | 34 kg (75 lbs.) |
Weight (per speaker with stand) | 14 kg (30.8 lbs) | – | – |
AURUS
The AURUS subwoofer is designed to integrate with the AURA and AURELIA speakers. It features a 12-inch long-excursion driver with a 3-inch voice coil and is rated for 300W of continuous power. A custom passive radiator is included to support low-frequency extension.
The 12-inch driver is supported by a 1200W bridged Class-D amplifier and dual input filter systems. This configuration is designed to support precise integration and phase coherence, making the AURUS a natural extension of the main speakers.
The AURUS subwoofer includes line-level (XLR) and high-level (banana plug) input options. It features an active analog line-level filter and a passive high-level filter, with preset profiles matched to the AURA and AURELIA speakers. A level control allows adjustment of output to align with the main speaker system. The compact enclosure supports a range of placement options in different room setups.
Specifications
AURUS Subwoofer | |
Speaker Type | Powered Subwoofer – Sealed |
Price | €13,500 Each |
Driver | 12-inch driver with a 3-inch voice coil |
Passive Radiator | Yes |
Frequency Response | 18 – 45 Hz for AURA (18 – 75 Hz for AURELIA) |
Inputs | 1 set Line-level (XLR) 1 set High-level (Banana Plugs) |
Input impedance for active filter connection | 10k Ω |
Input impedance for passive high-level filter connection | > 470 Ω |
Output Level Adjustment | +/- 6 dB active input (0 or +3 dB passive input) |
Amplifier Type | Class D |
Internal Amplifier Power | 1200 Watts short-term RMS |
Finish Options | WhiteBlack, GlossHorizon, BlueStarlight, Amber Elegance, Iron Grey |
Dimensions (HWD) | 490 x 330 x 450 mm 9.2 x 12.9 x 17.7 inches |
Weight | 45 kg 99 lbs |
The Bottom Line
Estelon, with 15 years of experience, has established itself as one of the leading luxury loudspeaker manufacturers in Europe. While still a relatively young company, it has steadily gained recognition among audiophiles for its distinctive design approach and engineering.
Building on the reception of the AURA loudspeaker, Estelon is expanding its offerings through the new “A Series,” designed for both music listening and home theater use.
For attendees of High-End Munich 2025 (May 15–18), Estelon’s exhibit will offer a look at the latest developments in its product lineup.
Pricing & Availability
Check the availability of the full A-Series product range – AURELIA, AURELIA Centre, AURUS, and AURA – with authorized dealers, including US and Canadian dealers. Prices listed below are MSRP. Canadian and US prices forthcoming.
- AURELIA Bookshelf/Standmount Speakers: €14,900 (Pair)
- AURELIA with stand: €17,900 (Pair)
- AURELIA Centre Speaker: €7,500 (Each)
- AURUS Subwoofer: €13,500 (Each)
- AURA Floorstanding Speakers: €19,900 (Pair)
Related Reading
- Estelon’s X Diamond Signature Edition Speakers Feature Some Rather Interesting Upgrades and A Hefty Asking Price
- Castle Windsor Loudspeakers Are Back: Handcrafted British Hi-Fi via MoFi Distribution
- Stratton Acoustics Element 6 & 8 Loudspeakers Dazzle at AXPONA 2025
- TAD’s Next Generation ME1TX Standmount Loudspeakers Aim to Shatter the Performance Ceiling Below $20,000
